1940_dodge
So I have copper 3/4" piping that I want to run along the walls in my garage. Do you all solder/"sweat" the pipes after you've mounted them to the wall itself or do you do everything on the floor then mount it?
Complicated piping can be loosely assembled in place to determine the pieces needed and angles, then sweated on the workbench or floor where you can rotate the piece around fully. Then attach that to your longer runs up on the wall.
I need to build an air dryer setup soon and plan to mount it all to a piece of plywood so I can fab it up easier on saw horses and then just mount to the wall later. If I need to move it, it will be a lot easier to so as an assembly.
