jwest7788
Hey Team,
Recently bought an air compressor from a gentleman on my local classifieds.
(White = Snow, Lame.)
Advertised as 100Gallon. Clearly has a retrofitted pump on it, not sure about the motor, but doubt original.
In particular I'm looking for help deciphering the label on the tank and not blowing myself up in testing.
After scrubbing the oil/dirt and paint off, I believe it reads:
CJWA4778
CSA5427
SH4573A
5 6 45
I gather the bottom line means "Old as hell" (I.e. 5th of June, 1945)
If you can help with the label, that would be sweet, but in the mean time:
I would like to hydotest the tank, but my faucet has already frozen for the winter, and I can't think of an efficient method of moving 100 gallons of water. (Thats 378.5 Liters for my fellow metric users)
Alternatively, I think of it like two years worth of milk jugs, at one jug a week. (alot)
Alternative to a hydro test, I wanted to confirm everyone's thoughts on filling it to 135 PSI with my other compressor (While safely in a totally different building)
The end goal is to run this bad boy at 125 PSI for normal use...
Other notes:
The pressure switch was set to cut out at 70PSI upon arrival. (This is the red flag that has me feeling like treading lightly, and from far away, haha)
The seller explained that this was his fathers, and his dad was downsizing. (To me this indicates good things, but to be taken with a grain of salt, as it was a 'seller' making these comments. -- Seemed like a really nice guy though, got to talking about his kids playing air hockey etc, but who knows)
Tank appears to be 1/4" thick, instead of typical 1/8", will confirm.
The pump appears way to small for this size tank:
Clearly retrofitted, as fresh paint, bright orange. Unlike everything else.
The motor stats:
2HP (is what's shown on the label. Based on what I can see, assume this is actual HP, not peak HP. For discussion, let's say Peak HP is 5hp)
1725RPM
240V 12A
Large and heavy, lol.
Can grab more pics as needed, but in summary:
Anyone know what the label means?
Alternative tests to hydrostatic pressure test? (Fill from afar, and confirm it can handle it doesn't seem safe, any method to fill to 200PSI from a distance?)
Alternative 100Gallon water transfer techniques?
Any other tips or insights?
Preemptively,
Yes, I have seen this: (top right corner)
And am aware of these:
https://www.google.ca/search?q=air+...a=X&ei=jLFjVO-uLpK5ogTXnYGQCA&ved=0CAcQ_AUoAg
(That's why I'm here)
CJWA4778
CSA5427
SH4573A
5 6 45
Other notes:
The motor stats:
1725RPM
240V 12A
Preemptively,
