I was experiencing what was seeming like some excessive resistance when trying to remove at least one of the four spark plugs from my '92 Accord. While unscrewing as it was becoming close to being out, it began getting tighter to turn. I did manage to finally slowly work it out by applying a little carb cleaner down close to the threaded part of the plug and turning back and forth slowly to break up the apparent carboned-up threads which I've been advised is likely the issue. Fairly certain there is no cross-threading going on, as I have managed okay to reinstall the plug without much problem. But still I'd like to go ahead and run a thread chaser into each spark plug hole in the head, particularly the one I noticed the unusual tightness I described above. I'd be trying to clear some of the build up carbon from those threads with the chaser. However, the design of the head on this car is such that the spark plug wells are too skinny to insert the typically available spark plug chasers like this:*@#$http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Spark-Plug-Thread-Chasers/_/R-SER730_0006401120*@#$which I've already attempted to use but can't because the hex size for the socket requires a 13/16” socket and that's too wide to fit into the hole; even a thin-walled socket is still too wide. So I came across this info in a forum where somebody was describing a homemade thread chaser for the job, which I would like to try: *@#$http://forum.miata.net/vb/showthread.php?p=6412358#post6412358
My question is in regard to the thickness of the metal cut-off disc for the angle grinder. The disc in the instruction specifies the use of an .045 (and shows a Norton brand disc) whereas in my location that size is unavailable at any local outlets. For my angle grinder the closest disc size to that is 4 1/2” x .045” x 7/8”. Of course that might seem like an insignificant difference but still I wouldn't mind some opinions/comments as to whether that could actually matter much, and maybe any input as to whether the homemade tool should do the job fine or not. I'm a little unclear as to what it is about thread chasers that make them work; what is it about the notch(es) that “chases” the threads. Plus, in the homemade one, I suppose I need to get that slant on cut just right across the threads too, and not sure how much luck I might have doing that.
