That vise has a very "Record" or "Paramo" look to it. Not surprising, since those are English made.
The jaws will open to 9". Going any further allows the ACME screw to drop out.
Would help if I had a line drawing with the proper nomenclature of various parts, and especially any bearing surfaces. The live jaw is part of a slide; the slide has a raised wear pad running its' full length on both sides.
Fretters: are you talking about Gunpowder's vise being a Parkinson?
Nope. That originally grey one above of mine, which I posted the photo's of to show him the various parts. That's the one which we thought might be a Paramo, if you recall. The only identifier on it is that RD689821 number on the cast, with no manufacturers mark. This one:
It's taken a few months, but finally solved the mystery of whom the manufacturer of those was.![]()
Do you buy that color (sorry colour) paint by the bucket (liter of course)?
Looks good. The handle seemed to have quite a bit of pitting compared to the rest of the vise, no vice?
I am finishing up my Parker 436. I have a question about the hardware Parker used to allow the handle to be "fixed" within the slide. See the photo.
I have cleaned up the handle and inside the threaded hole I did find the brass disc that rides against the handle, but the rest of the hardware is missing. Is the disc held just by a set screw, or is it more complicated, such as with a spring? A picture of the hardware would be great so I can replicate it. Thanks for any help
Fretters, Ex and All: we've been talking about taking a piece of pipe or conduit or dowel to push the main nut's spring back while removing the holding pin to take the main screw out of the dynamic jaw. any pictures to share of that so others can see how to make life a bit easier removing those pins from Athol, Record and other vises that have those springs?
In my 974.5B it has a set screw, spring, then small piece of steel. I replaced the steel with brass, figured it would be easier on the bar. I've seen others use a BB or ball bearing.
I have ordered the set screws since the 7/16 - 14 thread required by the handle is not common and was not stocked at the hardware store.
I want to thank everyone for the detailed replies. They are very helpful. I have ordered the set screws since the 7/16 - 14 thread required by the handle is not common and was not stocked at the hardware store. I'll match it up to a spring and reuse the brass disc.
Well I was bored today so I used a piece of 7/16-14 threaded rod to fabricate a set screw and found a spring about the right size.
It seems to work OK, so problem solved.
Here is another repair that I will fix, I am working with the owner on options, I am leaning to cutting a pocket and fit a piece of steel and pinning it down then re-machining the face. I do not want to weld if I can get away from it. I need material there to re-pin the new jaws. Any other suggestions?
