Hanging brake calipers ?
jc5205
When doing a brake job how do you hang up the calipers ?
I normally set them on a milk crate or use a bungee cord
I see OTC makes a hanger does anyone use that ?
gigamel
Bicycle spoke - extremely strong and can be bend without breaking - to fit any situation.
J
jc5205
That's even better than a hanger, but I think my wife will notice if I take a spoke vs a hanger
J
jc5205
The short rubber bungee works for me too, now only if my kids would quit taking that size
Reminds me I've got to buy a couple more
michael murder
What's bailing wire ? & don't say for bailing
It probably did originate for baling but it's kind of like duct tape in that you can use it for all sorts of things, usually tying and holding stuff in place. It's sometimes called mechanic's wire.
J
jc5205
I use a small pad compressor or c clamp to compress the pads
I see they make a tool for that that looks like a caulk gun
J
jc5205
Then do you just throw out the wire after you use it or put it in your box for next time
michael murder
I re-use it but if you do a lot of tight bends it will eventually weaken and break. Kind of a replace as needed sort of deal.
It's definitely worth getting a spool and putting it in the toolbox.
I had a rusted out exhaust hanger break and I was dragging my entire exhaust system down the highway. Having some baling wire really saved my bacon.
J
jc5205
I'm going to get some
My wife use picture wire a bit, maybe she's teaching me a thing or too
Shadowdog500
Down the shore
5" or 6" S- hooks from the garden section of ACE hardware. I hook them onto the coil spring. They are usually a buck or two a piece, but recently got three for $2 on sale during a fall sidewalk sale. They look exactly like the OTC hooks. I hang them on my lift column so they are always handy.
Before that I zip tied them to the spring
Formula
I have some hooks especially made for this by OTC. Very heavy duty. You could easily use some of the other methods mentioned, they all work well. Since I use them almost everyday, I invested in the nice ones made by OTC.
Fedwrench
Valley of the sun
I usually just lay the caliper out of the way or wedge it in the suspension so it doesn't interfere with the pro cut on car brake lathe. Those OTC hangars are on the long side. we're just talking about positioning the caliper so, it doesn't dangle from the brake hose so, there's no need to over think it or spend a lot of money. :dunno:
Buckgnarly
VT
Used to use a piece of bailing wire, now I use the S hook ends from broken rubber tie down straps.
premierplayer
Maryland, USA
Bailing wire = as in bale of hay, before the poly string used today was steel wire
bailing wire is a close cousin to mechanics wire and rebar tie wire
I use a gifted (as in free) roll of rebar tie wire, cut it off and throw it away after I bolt the caliper back on.
monomach
Illinois
I use heavy-duty reusable zip ties. They're some fancy $1/ea things from ULINE that are rated for like 250lb.
abvw
Toronto, Canada
Snappi-****** tarp straps. Cheap, durable, Canadian made. Hook one end to the caliper and the other to the coil spring, upper control arm, fender liners etc etc. For big and heavy calipers I loop and wrap a longer strap and hook both ends to suspension components.
Sent from my Q10 using Tapatalk
firebox40dash5
The reason I'm asking this , I didn't know if the pros use something special tool
I buy the electrical contractor-size bags of 8" and 11" zip ties for the shop at HD for like $7/1000, and we have a roll of baling wire. You'd need to give me damn compelling reason to buy a special tool when either does the job for under a penny. :D
redwrench60
East Tennessee
I've used wire and bungee cords and just propped them up on the upper control arm but if I'm tearing down the whole spindle or trying to make room to work I stole a good idea from srmofo on here and use a large Vise grip welding panel clamp. I open it up, hook one end on the spring or hook it to the frame and hang the caliper from the other end. Quick and easy. I already had the clamps and I keep them handy.
