My 1st WTF is it thread!
RivennHewn
PNW
Not very often that I'm completely stumped, but this thing?
What the hell is it?
66dave
Boise!
My guess ....Looks like some sort of mechanical to electric feedback. I see a spur gear turning into a linear motion that is connected to a variable resistor...
What was it on? Where did you find it?
R
RivennHewn
PNW
Came with my new (very old) Sypher metal lathe.
Did I mention it was Free?
wildbill23c
Idaho
Some sort of speed reduction device for the metal lathe I would assume. I'm not a machinist, but that would be my guess since you mentioned the lathe.
theoldwizard1
SE MI
I am really stretching ...
The gear box gives that small motor a lot of torque. The arm on the end of the gearbox output could drive something in a liner motion, back-and-forth.
Some kind of gear hobbing or keyway broaching add on for the lathe ?
R
RivennHewn
PNW
The small silver cover on what looks to be a transformer is labeled "Marchal"
No part numbers of any other info.
Speed control for an auto-feed on the lathe?
I'm thinking that's a motor also but maybe not AC. DC variable speed? Then the GR box and further reduced via the chain drive.
CNGsaves
KS and OK
Time to get guy's name, forwarding address, & phone number from Realtor for your free score !!
Wealth of knowledge likely to be gleaned from the guy who moved and left that behind.
Stuart in MN
Minneapolis
Marchal is (or was) a european company that built automotive electrical equipment. It looks like a home made setup for some unknown purpose, with a windshield wiper motor hooked up with a chain to a right angle gear drive.
rancherbill
Foothills County, Alberta, Canada
What's on the other sides of the device?
I have never seen something like this before. It looks like the shaft goes in and out. Maybe its controlled by a magnet and shifts the gears from locked to free wheeling when power is applied.
R
RivennHewn
PNW
The mounting bracket is made from a section of aluminum C-channel with a green coating, similar to what I've seen in aircraft manufacturing.
I do live in the land of Boeing engineers.
It has a 12V stamp on it. I tried hooking it up to a battery, but got no response.
Google searches turn up nil.
Gear reduction unit: 30 revs of the gear to 1 of the arm.
theoldwizard1
SE MI
I'm thinking more along the lines of a trim tab or small flap motor
I second that, especially after seeing that piece of "green" aluminum !
I don't see any limit switches. They could have been mounted elsewhere and wired into the circuit.
Fretters
South Yorkshire, England
That could just be something chucked together by someone to confuse the **** out of people a few years down the line, as it's doing now. :D I know full well I could find doing something like that highly amusing whilst building one. That's a "keep you chuckling well into old age" piece of kit, IMHO. :evil:
