04fivefour
So last night I installed and wired up two commercial westinghouse fans controlled by 1 Dayton fan speed controller. When I turned the breaker on everything was fine but when I turned the fan controller to on it popped and fried the controller and tripped the breaker.
I wired the 2 fans like you would a regular lighting circuit. I wired the conroller like you would a switch. The controller says it is rated to 6 amps and the fans say that they are .5 amps a piece.
Did I wire them wrong or is the fan amperage rating for running not start up? Here are links to the controller and the fans.
http://www.grainger.com/product/48C172?cm_mmc=PPC:GooglePLAC-_-HVAC%20and%20Refrigeration-_-HVAC%20Controls-_-48C172&ci_src=17588969&ci_sku=48C172&gclid=CMLF9ZTWhMICFZFzMgodRTIAtQ
http://www.westinghouselighting.com/ceiling-fans/56-inch-ceiling-fan/industrial-56-inch-three-blade-indoor-ceiling-fan-7812700.aspx
