onemoretry
- Joined
- Apr 12, 2008
- Messages
- 326
I am in need of something like this for a jeep with 37" by 12" tires. Does anyone think they will go that big or know of another product that will?
DREDDYBEAR- This one? Does anyone else have this bandsaw? Any good?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93762
Anyone have the pneumatic Roller seat?
Only $20 in my flyer..Hard to beat..Thinking of picking up a couple.
i bought a hf 40 inch roll cab at the fargo store.[yes even nd has a hf] very happy so far. seems every bit as good or better than my cman. will probably get a side box some day. the chest seems ok but not enough drawers for it's size in my opinion . pass on the cab fail on the chest. put your old box on top or get something different.
correct. the quality appers to be fine and if it meets your needs by all means go ahead. it just seemed to me the top box needs more drawers. i think the drawers are to deep for my needs. if you load your drawers up with pliers ,screwdrivers. and smaller wrenchs like i do than they are too deep. things get lost in the bottom. if you have large boxes and cases to store it may suit you better. just giving my opinion
for my use and personal preferance i like more drawers. the top chest my store carries has only eight drawers. i like to keep most sockets and related items in the top open part.in the drawers of my cman chest starting with top drawers down i have screwdrivers, pliers, vice grips. and then wrenches in racks in the remaining drawers in the narrow deep drawers it is tape measures and misc. with electrical and wiring in the next two drawers. most of my tools didn't have plastic cases or i am not using them so i don't care for the deep drawers. my cman with 10 drawers just fits my needs better. i just think the hf chest would be better suited for most people with more drawers like their cabinet has. hope that answers your question . and also, nice ride. not quite right for my several miles of gravel to the paved road or for checking crops but looks fun anyway.
HF portable band saw-FAIL. Burned up after 2 yrs of limited use
3
Has anybody tried one of their English wheels? I know that if it sounds to good to be true, it usually is, but I thought for occasional use it may be alright? I mean, I cant even buy the materials to build the frame for what this thing costs?
I tried to post a pic, but I cantAnyway, I was lookin at the "heavy duty" one, but the regular one is even cheaper $299 to $599??
Anyone???
They ****. Stay far - far away. The frame is so flexible it is useless and the wheels are severly out of round and many of the bearings are so stiff you can barely turn them.Has anybody tried one of their English wheels? I know that if it sounds to good to be true, it usually is, but I thought for occasional use it may be alright? I mean, I cant even buy the materials to build the frame for what this thing costs?
Anyone???
Has anybody tried one of their English wheels? QUOTE]
Ive used a buddies. I would definately brace the top arm to the side arm. It flexes quite a bit. If your not a master fabricator, this will work fine.
There are no circumstances under which I would use a product sold at HF that spins rapidly or is under enough stress so that a disintegrating piece flies into a part of my body that does not readily regenerate.
Sanding flaps, grinding wheels, die grinders...you get the picture.
Just a quicky:
<clip>
Cutting discs for 3" cutoff wheel. FAIL made in Russia and prone to fly apart. Get what you pay for but I keep buying them cuz they're there. I have a 3m cutoff wheel green? I got who knows where that's lasted probably 2 or 3 times as long as the hf. Same with their 4.5", unless you find dewalt discs
I'm a mechanic, and use these almost daily. They are a great buy. I'd recommend them to anyone who needs an affordable set of impact sockets.Pittsburg Forge HF 1/2 inch drive deep 6 point impact socket METRIC. Tentative pass. I havent used them yet but if they're anything like the other impact sockets from HF, they are the buy of a lifetime.
Even though I hate buying Chinese tools I saw Harbor Freight was having a sale on some clamps so I said what the hell and bought some. The 6" were $3.49 or something like that.
Buying tools at HF should always include some basic inspection for defects, but you can always take them back and pick out a few good ones. Chances are good some batch of clamps came in, and over a few days the good ones were picked out and the bad ones left behind.
Guys at the the register should do what they do in a grocery store, open each dozen eggs and check for broken etc.
Off topic;
What the heck kind of grocery store has the time to check YOUR stuff for cracked eggs?
Just curious. I shop at Costco and Winco and learned to check on eggs when my Grandmother took me shopping... In 1963...
Never had a clerk check for me though.
I have used the cheapest HF 4.5" and 4" cutoff discs (PASS)
in my Makita 4.5" angle grinder for years.
Wow, good hustle, Chris. You came out smellin like a rose.
the price that day was 149 plus tax, he paid 100. HF automatic compressor drainer kit MISERABLE FAIL!!! A great concept but it falls very short in execution. The kit consists of a pneumatic actuated drain valve for the compressor tank and the fittings and tubing to splice it into the pilot/unloader line between the compressor tank and pressure switch. Here's the rub...The kit claims to have a 1/4 inch NPT street T, a 1/4 inch petcock. a 1/4 inch tube fitting x 1/8 male NPT fitting and 8 feet of 1/4 inch nylon tubing.
In reality, the kit does indeed have the drain valve, petcock and the street T but the 1/4 inch tube by 1/8 pipe fitting is a 6 mm compression tube and the 1/4 inch nylon tube is 6mm polyurethane tube. The instructions tell you to cut the tube between the compressor tank and the pressure switch and install the compression T and run the branch to the drain valve, this all works fine if you happen to have 6mm plastic tubing from your tank to the pressure switch. The tapping on the valve for the plastic line is not 1/8 NPT so you are stuck with using the fitting they give you and using the 6mm tubing. I ended up buying a 1/4 inch compression T, cutting off and machining a piece of the 6mm T and soldering it into the branch of the 1/4 inch compression T. Then I installed this T into the line from the tank to the pressure switch. Once everything was installed, I found the handle of the petcock was just spinning around and would not allow you to adequately shut off the petcock, I removed the petcock, re-staked the handle and re installed...although you could now tighten it, it would not shut off nor would the threaded connection between the petcock and the street T stop leaking even after being re-taped and re-tightened. I chucked the petcock for my original lever operated ball valve drain **** and even now still have the slightest seepage at that threaded connection! The threads in the supplied street T only go in about 3 threads so there is little engagement when you make it up.
So if you are feeling creative and don't mind a little extra time and money spent, this thing actually does work but I really can't recommend it to anyone without a lathe and patience!
My experience disagrees.
in my Makita 4.5" angle grinder for years. The discs don't last long, but are so cheap (about 50cents each) it's well worth it, and not one has flown apart. You need to let the abrasive rather than pressure do the work. Push too hard and you chip the disc.
I bought the cheap straight die grinder and the 3" discs also but haven't tried them yet.
Of course I may be scaring off disaster by always wearing protection.
JME - Rod
I was in the need of some c-clamps and I have been looking around for a while for some American made ones that I could afford. Nothing yetEven though I hate buying Chinese tools I saw Harbor Freight was having a sale on some clamps so I said what the hell and bought some. The 6" were $3.49 or something like that.
Check this one out:
I haven't used them enough to tell if they will hold up to some abuse but there aren't 2 out of the 8 that look the same or look like a quality c-clamp. I'm keeping an eye out for some USA ones.
Hose grip pliers - FAIL. I feel like I've used these enough to make a fair assessment, and I really don't like them. They flex too much so they don't provide much grip, and the teeth don't seem to bite into the hose either. On 2 of them the jaws bent.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=37909
