Fave Non-Standard Hand Tools?
Stuey
28m above sea level
Over at ToolGuyd, I was working around an automotive and industrial hand tool theme this week, and took the opportunity to review a couple of tools I've owned and enjoyed using for years, as well as some I recently checked out.
Here are a couple of my reviews from this week:
Facom angled socket wrench
Wera sliding T-handle
Proto locking extension
Wera swivel-sleeve extensions
SK thumbwheel ratchet
A couple more are scheduled for tomorrow, including Facom wrenches and PB Swiss bit sockets.
Anyhow, what are your faves? Bonus points if it's something non-standard or unusual, like the ones here.
Ruger_556
I've been meaning to buy those locking extensions maybe in the impact version though...
matthew
Duckbill pliers. Not overly common in homeowner toolboxes, but I really feel they're must-have. Just so useful. I have three different sets - Channellock 718, Knipex 29-11-160, and a mini pair of Craftsman.
Ruger_556
Long reach 45 degree Snap On pliers, absolute life savers in a tight spot.
T45
Proxxon thin combos. Come in handy when you need a thin open end. The ring ends are robust and the 13mm tested to 240NM, just as strong as a snappy. They also are very compact as a set. Nice mix of features that.
Stuey
28m above sea level
I forgot about those!
I used mini Proto duckbills to fracture ceramic samples for microstructure analysis. Worked really well, but tougher samples required more than a scribe and had to be cut with a diamond wheel.
I've been meaning to buy one for home use, for tightening and flattening stranded wire but haven't had a chance.
JBradley500
Snap-on A177a
This thing is great for removing clips, linkages, hoses, etc. I use it all of the time, and never for its original purpose.
unslow1
Illinois
That is one of the few new Snapon tools I have. I'm kind of disappointed that I don't use them much and they rusted immediately. Oil took care of the rust but I still don't seem to use them.
Stuey
28m above sea level
woodstockva
USA
Snap-on A177a
I found one of those under the rear seat cushion of a 1990 Honda Accord I parted out! :)
jeffmoss26
Cleveland, Ohio
Okay ... what is a "master follower" ?
A plug follower is used when rekeying a lock. It holds the top pins and springs in place while you have the plug out to replace the keypins.
The Keedex master follower has a radiused section that you can turn so master pins will fall out of the top.
