t12 / 8 foot conversion options?
just1more
When I built my shop 8 or 10 years ago, I bought used 8 foot fluorescent fixtures that were removed from a store. They use the single pin T12 tube. The lights have worked fine... until a year or so ago. I now have quite a few that are not working. And... it sounds like they are phasing these tubes out.
I need to start repairing or replacing them. I would prefer to upgrade the existing fixtures to a newer electronic ballast and tubes, if possible. Can I upgrade these fixtures to the T8 ballast? Do they make a single pin T8/ 8 foot tube that would work with my existing lamp holders/ or do they need to be replaced as well?
any ideas what my best options are? (cost /light output / etc.) ....btw, I have around 25 fixtures that will eventually need attention. :sad:
here is pic I happened to have that shows some of the fixtures when they were all working...
Norcal
8', T8 lamps are considerably more expensive then 4', I would look at kits to convert them to 4-4' T8 lamps or just replace them w/ 8', 4 lamp tandem fixtures. To add to the comment about the cost of 8' VS 4' lamps, 4-4' T8 lamps are cheaper then 1- 8' lamp.
gatorgrabber
Gainesville, FL
I converted the five 8' dual bulb lamp fixtures in my garage a couple of months ago and couldn't be more pleased. I picked up the T8 conversion parts (bulb holders and ballasts) at my local supply company. I went with single pin 8' bulbs instead of dual pins. The entire conversion took just a bit more that 1 hr to do all five fixtures. Remove the ballast, pop the old bulb holders out, snap the new ones in, attach new ballast, reattach wires and you're good to go. For bulbs, I went with HO units; I like to cast a shadow in my work area! :cool:
Mustang51js
Haskell nj
Not sure where they get their bulbs from but the supply house sells t8 8ft bulbs for $6 each,and yes you can just change the ballast,and get single pin t8 bulbs
btlegacy
NC
We just went through the same thing at work and figured up that it would cost about $26 per fixture to convert them plus we would have to use the less common 8 foot T8. We were able to get the 4 bulb 8 foot T8 Fixtures below for $36 with 10% off coupon and just do a straight swap
8ft T8 Fixture
cybrdyke
USA
OP, the lamp you seek is a F96T8. Commonly available. The ballast is gonna have a 259 in the part number, ie: Advance ballast ICN2P59 , also common. The swap is simple, just follow the wiring diagram because there is a small difference.
CD
J
just1more
Thanks for the info! I will start to research the options.... with 25 fixtures to eventually update, its probably going to be an ongoing project.
kfsinc
Looks like you have the light question answered - now to the important stuff.
Looks like a mid 60's CC Mustang? Several friends in Wisconsin had those growing up. That one looks to be in very good shape! What motor?
J
just1more
Yep, It is 69 Mustang- powered by a transplanted 350 Chevy... I have a "few" old 60's Correct Crafts around. Gotta love the old inboards!! :thumbup:
J
just1more
Thanks for all the input! ... I bit the bullet and ended up buying twenty one new fixtures. I decided to go with the 4 lamp, T8 , 8 foot fixtures. They were on sale at good ol' Menards for about 30 bucks each. Besides the fixtures being on sale, the 4 foot / T8 tubes are about half the price of using the 8 foot tubes.... plus easier to handle.
...now to get time to start installing them....
