Hostyle
I'm looking forward to seeing the result! The zipper idea for the domino should give a lot of strength.
...My original intention was to just bevel the top edges instead of using pulls but I realized that when I built the drawers I maximized the size by using stretchers on edge and that wouldn't give me enough room for that option. There's ways around it but they would have separated the drawer edges even farther and I'm trying to book match and show off the continuous vertical grain so I wanted to make the drawers edges very close....
That's funny - the first thing I thought of was "Canon Professional Service? - just cause I'm using Instagram?" Then I got it. I'm slow.
It looks pretty good but I think I used too thick of a domino so my next joint I'll size down and see how it works.
Gregor
Gregor,
what an amazing build.
You have a very good taste!
cheers from italy
I just read all 61 pages in one sitting. Two cups of coffee and I am finally brought to the end. Absolutely fantastic build, Gregor.
Ya, the 4mm are better, but I think you used too many Dominos. I think a biscuit joiner is better for this type of joint.
Also, use the Collins prep Ply router bit on one side. When you clamp the two panels together only the veneer sides touch the opposing face, compress slightly which closes up the line and when you clamp the joint disappears.
Tim
That's a good idea. I wanted to do a small garage party - you know, the one before I invite the entire GJ and the internet, but Jwoo nixed that idea. Just as well as I would have put my time into cleaning the garage instead of the kitchen. Smart girl.
I think in the spring, when I finally get around to the new garage door I'll do the big party. I want to make sure that everyone I know with a bike rides to the party. I would love to see about 30-50 bikes in the driveway.
Gregor
Happy Birthday!
We all had a great time last night, thanks for including us.
Here's my biggest **** up. That end panel...
Gregor
Awesome job Gregor! Love these last updates. In the pic of you staining, you can see your clamp holder setup in the background... hows that set up?? Looking to build something like that for myself but not really sure where do start without it looking ****** haha.
I'm wondering what plans you have when the house is more or less done and you can turn your full attention to the garage.
My ideal workshop was Kenny Robert's British MotoGP shop but for the life of me I can't find a photo of it anymore. The nearest I can find is a shot of HRC's workshop:
My goal with the shop is to follow the lead of LilScorpion and make/find a place for everything so that the shop is neat. I'm a hot mess without a system of organization and I'm very much a creature of my grandfather's mantra, "a place for everything and everything in it's place".
So, long terms plans are to have my welding table blanchard ground and make a new base with wheels. To build a long bench on the wall with the window. To make a new garage door in the hanger style and to find "a place for everything" even though new tools (and motorcycles) are constantly finding their way into the shop.
This winter I'd like to build a swingarm for the Guzzi but that will require the digging out the welding table from all the junk piled on top. Without a place for everything, everything ends up all over the place.
Maybe a longer term goal is the one Ben and I jokingly discuss which is to extend the garage underground another 20-30' or perhaps up as well.
Gregor
I was just wondering if you've ever been to Rev'It Europe in Oss, NL?
All very swanky (that IS a compliment by the way).
I did a similar thing for my German Bauhaus posters and it does look good if you are into the modernist vibe.
Sure. It's two cables on two pullies for either side of the table. The brackets are centered in the balance point for the table.
Those two cables are cut to length so that they end at the same point (one is longer) and they go off to the side. Mostly to get enough room so that there's sufficient cable after the two join into one cable. The two join the single cable which runs in a single pulley.
This pulley redirects the run to the hoist which I mounted over the bike bay so that it could be used to lift a bike.
I used another pulley below the hoist so as to redirect the cable from the horizontal to the vertical so the hoist can be just screwed into the ceiling. I angled the hoist so that the four long cabinet screws could each be in a different 2x3 to spread the load.
You can see the cables holding the table in this shot. I fastened it to the side so I could lift it as high as possible since my ceiling is only 8' tall and space is at a premium. The other thing you can see is that I ran an extension vacuum tube along the ceiling that is paired with an extension cord from the vacuum's powered switch. This way when I lower the table and use a tool the vacuum and power cord are hanging from above and not tangled on the floor. I had done this a while ago and it worked well so I redid it in a more organized way. The other benefit is that the vacuum is now central to the garage and I can vacuum up the floors pretty easily.
Gregor
That's very cool. I think that my angle would put me at 71% but maybe I can redo it to make it better. It's been good so far.
Gregor
Gregor,
That drawing about the angle is not what you have, since you have pullies on top, redirecting the force of pull from the table. The pullies redirect the vertical force of holding the table to a horizontal force. The horizontal force on the cables is the same as the vertical force.
Now the force on the pully itself is something else, and would be similar to the 90 degree vector force "ok" angle in the link he attached, though with a resultant force 45 degrees to the angle of the base plant.
This made sense in my head, but not sure if it came out clearly enough. End result is that your table is light, and the use of pullies limits the amount of force required to get the table in the air.
Later,
all this talk is making me relive my statics and dynamics classes. dont do that![]()
Gregor, thanks for sucking about 3 hours from my life. Ha. As a guy designing/manufacturing equipment for guys like you (well, more on the film side actually) your collection of skills, and voracious appetite for learning new ones is inspiring. The bikes are gorgeous, your commercial stills even better..and I wish I had never read this thread...particularly after working until 1:30 on my own shop rebuild.
So my question... which came first, the chicken or the egg? Were you a photog first and picked up the machining skills later, or vice versa. I'd love to hear your story.
