Atlas drill press "restificaton"
xs650shawn
Hesperia, CA
Didn't want to call this a full restoration. I got this press on craigslist for $150. Bought it with the intention to use it, still plan too. Was pretty rough when I got it, but the previous owner was willing to deliver, so I didn't argue the price. Found out by some searching and help on a vintage metalworking machine forum (owwm.org) that this press was made in the forties, and was originally a bench model. Someone prior turned it into a floorstander by splicing the post with fence post. Original thumbscrew areas for motor post mounts were also broken, but it functioned. Decided to clean it up, quick repaint, and replace any necessary parts.
Only major part needing replacement was the post. Not easy to find at 2 3/4" diameter. Not a common size, but found one near enough to the original length. I know most common Atlas color seems to be gray, but when wire brushing the parts, I found this green to be the base color. Rust-Oleum Sage green seemed a close match, and I kinda liked it.
Spindle bearings were still decent, and everything else seemed tight, so I put it back together. But the head fit tight on the post. I then had to build a base for it, as being on my workbench made it too tall. So I built a wooden rolling stand.
Replaced the motor with a new 3/4 hp Marathon reversible motor, with a directional switch. Now I just need to replace the test cord with a heavier one.
CoopVA
Virginia
Looks good. Gotta love the Arc of Shame...
You've got my compressor...
gilbo
yet another piece of americana, saved and put back to good use, nice job there
kelpaso1
MEMBER EMERITUS
New Brunswick
Just wondering how that happens?? I've seen that a few times but not sure how someone manages to do that. I've had drill presses for 30 plus years and the worst I've done is drill a hole into the vise but never the table:dunno:
Big Pete
big stuff doesn't fit in the vise, so gets clamped directly to the table, and people don't put a chunk of wood under the work ( or one thats too thin). Viola, drill holes in the table :(
