only thing i trust mine for is torquing lug nuts, even then I have to take my time and hold it perfectly parallel to the wheel so it clicks when its suppose to. Head is full of slack. Can only imagine the extra effort to make sure the new style works correctly.
I just assume, generally speaking, that everything in that store is made of chinese children. (no typo)
It never crossed my mind that they would be made anywhere else, I mean ****, your getting a torque wrench that is designed, materials collected and made, and shipped from across the world for like $10 witha coupon, and they are still making money.
What the hell do you really expect for that price? I'd be impressed if the thing held a socket on it for that price. Who really cares, you know what you are buying when you go into HF.
Lmfao! Exactly! Well said............
Sent from my bag phone...
I didn't realize that any of the HF torque wrenches were made in Taiwan, will be buying a dozen of each size that I can find that are still made in Taiwan as gifts! - thanks, OP!![]()
Harbor Freight torque wrenches, despite their low price, or country of origin, have usually tested to be accurate, according to most of the reports I have read in the various threads here.
Brand new and out of the box, when tested they are accurate. How about 6 months later of daily use?
I mean, even the Yugo was good right off the lot. 50 miles later though....
How accurate is any clicker type torque wrench after 6 months of daily use?
no those are made in Mexico with Chinese parts by Taiwanese immigrants.Does this apply to the ones that HF supplies to Snap-on?
Well, I'm off of work today so I decided to toss in some info for this thread.
Note - I'm not saying this is a scientific test, just that this is some casual data gathering by a DIY'er.
Also, how you pull can really affect the consistency of this torque wrench. A slow, steady solid pull that completes the clicking cycle seems to give me the best accuracy.
Anyway, here's what I did:
This torque wrench is about 5 years old and has been used a lot by me over the years to torque wheels and suspension parts. I also own CDI and Armstrong clicker torque wrenches and a couple beam torque wrenches.
I'm trying to give an honest perception of how the torque wrench works, good and bad, so I'll tell you exactly what I did.
I used my car as a testing device:
First, I decided to do a bunch of pulls to see how the consistency changed after several cycles. (All cycles performed with wrench set at 70 ft-lbs)
I didn't set the parking brake securely enough right off the bat and the car moved a lot on the first two pulls, which netted these low results. I actually would discount these, as I think it's my fault for not securing the car well, which gave inaccurate pulls that didn't follow through the click. But, to be fair, I included them:
65.7
65.4
The car was then better stabilized and I went through a number of cycles. Here's what I got:
67.9
66.9
66.3
67.2
69.7
70.2
68.3
68.2
68.9
68.3
69.1
67.8
69.9
69.5
69.3
69.9
69.5
Then, I ran the torque wrench all the way up and down and cycled it several more times. (NOTE - It's starting to get difficult to twist the grip on the this torque wrench sometimes. It may be reaching the end of it's usable life at 5 years and lots of use).
I then got these results (NOTE - these were all good, solid pulls that follow through the click):
69.9
70.6
69.2
69.8
71.0
71.0
68.4
70.6
Conclusions - If you can even take any conclusions from this unscientific example:
-Cycling the wrench does seem to help its accuracy and consistency.
-Consistent pulls that follow though the clicking cycle (for lack of a better term) give more accurate readings, in my case.
-This torque wrench is more than accurate enough for my needs.
-The HF torque adapter is a very interesting little tool that I've used quite a bit. I would encourage any serious DIY'ers to pick up a torque adapter. They're available from brands like Eastwood, Alltrade and I'm sure others.
-A torque adapter may be worth it's purchase price just to show a person how much their pulling method can affect the final applied torque.
Every torque wrench from there that I've tested has been within accuracy specs. Popular Mechanics also did a test that proved as much.
As much as people like to hate on the HF torque wrenches, they are actually really accurate and precise. As in accurate and precise enough to be used for engine, transmission, suspensions or whatever rebuilds.
But hey, many on this forum won't see truth if it were to walk up and hits them.
Lmfao! Exactly! Well said. Can't say i amsurprised. Thanks for the reminder, don't trust precision with these tools. Buy whatever you want, but you always, 100% of the time, get what you paid for...ALWAYS!
