ABSTIFFGS
Have had a few over the years. Never really use them.
I knew I forgot one. I have pretty much all the GW ratcheting kits. I don't use them as screwdrivers most of the time though, they're mostly used as ratcheting nut drivers. They are very nice and if I had bought them first I wouldn't need any other, but probably would still have bought them anyway.My Snap On used to be my favorite but I recently purchased a GearWrench set that came with a straight handle and a T handle. The mechanism of the GearWrench is almost as good as the Snap On and with my strength issues I've found the larger straight handle and the T handle to be easier to use. Not to mention you can pick up a nice GearWrench driver set for under $20 if you watch Sears' website.
All the time. I've been using this one for the past 20 years, and it still has all of its original bits. It's one of my most frequently used screwdrivers.
Jim C.
Oh Man! Jim C. I had this screwdriver and I loved it. I lost it at work and can not find another like it at sears, this thing was simple and GREAT.......
Yankee is "stuff the fat *** on and it drives the screw itself"They were once called Yankee screw drives .
do people still do this in 2014 with 800 lumen Cree headlamps that can be purchased for $36 including the 3400mAh rechargeable Li-ion batteries?![]()
I've got the soft grip SO, short and long bit shanks and a 1/4 drive shank to top it off! If you are doing lots of interior trim removal this is what you need. Powered drivers can be tough on brittle plastic (especially plastic in older cars), especially if you do not adjust your torque settings.
I also have a Milwaukee ratcheting driver and was decently impressed for the $20.
I'd rather close my **** in a car door than wear a headlamp.
I have a Snap-On and like it. It's very handy.![]()
Hey Q tools,
Unfortunately I haven't seen that model of ratcheting screwdriver at Sears in many years. I received it as a Christmas gift way back when anyone could walk into any Sears tool department and without even trying, buy a durable, affordable, made in the USA tool like that screwdriver. I miss those days. Anyway, I know that I've been using it for at least twenty years. It's not a tool I use every day, but when I need a screwdriver, that's usually the one I reach for first. I also remember that I liked the thing so much, I bought one for my dad for Father's Day right after I got mine a few months earlier for Christmas. I know my dad still has his because I used it this past weekend at his house. Like you said, it really is a GREAT tool. If I ever do see another one, I'll pick it up and send it your way.
Jim C.
Something not yet mentioned is the full length hex shaft on so many screwdrivers - Wera, etc. The idea of a hex below the handle is fine, and might rarely be useful, but I have worked on both aircraft and motorcycles where that hex shaft, particularly on longer drivers, rubs against a painted surface and grinds like a bit. The round shafts don't tend to do this.
JMO,
Dave
JMO,
Dave
