This is slightly off topic but I need your assistance in finding a plug that is outdoor rated and can except 8 guage wire and handle 50 amps.
I am in the process of having a flatbed built for my work pickup. I run a industrial air compressor and fuel transfer pump that I want to be easily remove when not in use, hence the need for a plug in.
I would prefer something like a trailer plug in setup with a door that shuts when not plugged in, but I can't find anything that will except heavy enough wire.
I looked at the Anderson connectors which are rated sufficiently and will work with 8 gauge or heavier wire, but they don't permanently mount the way I would like.
Any ideas?
Thanks
Any ideas?
Thanks
....completely wrong!
In the US, to be compliant, u select the plug or recepticle based on the HP rating of the motor.
