Father/Son Garage Build
fortbrick
Indiana
My father and I decided that with my increasing interest in cars and his main hobby being woodworking that our current garage would not be up to the task of multiple ongoing projects, storage, and a large amount of tools. We wanted to create a new working area that we would be able to grow inside of without worrying about becoming cramped with too many things... but we'll see how far that goes. Here's the link to the album on Flickr. Probably twice as many photos there.
It started with a drawing. Simple, but it would become the mold for what we wanted to build. We probably sketched thirty rough drafts before returning to one and then started to slowly modify it to suit our needs. A large amount of square footage was easily agreed on as we enjoy to work in open environments. We set overall dimensions at 48x32ft and went from there. The most time in planning was spent on deciding what size garage doors, and how many would work best. It was decided after many drawings that two 18x9ft doors would work best.
On Sept. 17th we broke ground and concrete prep began
There was a lot of loose dirt that came out from underneath while excavating the area. With the overall ground composition being clay I wasn't terribly surprised that this happened. Extra measures were made to reinforce that area.
A quick walk around of the area
Footers
Sept. 18 - Filling stone was brought in, as well as webbing and a moisture barrier for the concrete. Floor drains were also installed.
Sept 19. - Concrete was brought in. Had them angle the entrances through the not-yet-present garage doors for smooth entry and exit.
Oct. 1 - Started framing
Oct. 2 - More framing. Reinforced the corners and left open areas for wind to travel through.
My neighbor making a cut for one of the corner pieces
Standard height 7ft service door opening
Overall profile shot after initial wall framing was complete
We had placed the order for the trusses almost two months in advance, but the Amish business making them managed to lose our order... so that pushed us back about two weeks while they moved our order to the "front of the line" and gave us a discount which turned out to be negligible after the delay.
Oct. 15 - Our buddy that does framing brought in his monstrous cherry picker/forklift and helped get the trusses installed. We later decided to keep the machine around and used it to install most of the side panels and the roof.
Artsy shot
Another walk around after the trusses were finished
Oct. 17 - We began working on the roof. Getting some panels and the underlay put down.
One side finished
A couple inside pics. We didn't want any support beams getting in our way while working, so for quite a while we had these braces up to support the walls.
Oct. 21 - Roof is almost finished and more work began on sealing in the walls
Oct. 23 - Finished walls, removed braces, and installed exhaust vents
This is the Lull Highlander that we used often. Powered by a 4cyl cummins turbo diesel
Oct. 30 - Water barrier for the walls went up and painted the door frames
Nov. 8 - I was able to start moving some things into the garage temporarily
Nov. 12 - The garage doors went in. Love these things, they take three fingers to open and close.
I need to take some more photos to get things up to date, but the siding has gone up. In the next week or two we should have some nicer flooring going down, followed hopefully by electricity.
I know that this has been a really long post, so I hope you enjoyed it. I'll try to keep this thread up to date on new things happening.
ryolse
Colorado
Looking like a great use for the back yard. Maybe I missed something, but why did you only hip the one side?
ambenz
NW Chicago Suburbs
Dang...your garage is bigger than my house!
That's over than 1,500 square feet of man cave!
Very cool...would you adopt me?
Subscribed!
May I ask...why the odd roof design?
Half hip roof, half A-frame...hmmmm?
F
fortbrick
Indiana
Very cool project you guys have. Is this on your dad's property or yours?
This is at my parents place. I'm a student currently training to be a master Audi tech. I still live at home since school is 20mins away.
The hip on the front of the garage (east facing) was used to mimic the profile of the house garage to make it appear as residential as possible (although it's obviously very large) from the road. The other side matches the rear profile of the house. The extra storage and walking space of having that side of the roof done in the a-frame style doesn't hurt. I have a photo from down the driveway showing this. I think it makes the garage feel more "homey" and relaxed, rather than a work area.
Subscribed!
1536 square feet, to be exact! You are welcome to stop by if you're ever in the neighborhood and check it out. See above for your questions regarding the roof and the thought that went into that.
F
fortbrick
Indiana
Awesome career choice. Good luck!
Thank you. It'll be nice to get paid to do what I love.
Very nice. Love the roof line.
Will be watching this one.
Nice Volvo too.
Thanks! I have two of them. This one is pretty rare. 1 of 18 in the color, euro-spec, turbo motor and 5 speed. Other one is just a US spec sedan with an auto. Both in the same color.
F
fortbrick
Indiana
Here's some more photos that I found on my camera and a few new ones.
Oct. 24
Nov. 10 - Garage doors going in and siding installation. In a measure once, cut once scenario I suppose, our framing buddy made the overall height of the garage door opening about an inch too low. To fix this we had to cut into the header above both openings and clear out some space to make the door look correct after it was installed.
Nov. 29
Mounts for the exterior lighting
Bought some bricks, but they'll be going up in the spring since there is a chance of the mortar cracking in the cold weather.
View from down the drive
ryolse
Colorado
I completely get the want for the hip, it looks great. Just wasn't sure why it wasn't hipped on both sides. Looks great though and will be a fun work place with all the other normal cars/stuff in the attached garage.
ambenz
NW Chicago Suburbs
The hip on the front of the garage (east facing) was used to mimic the profile of the house garage to make it appear as residential as possible (although it's obviously very large) from the road. The other side matches the rear profile of the house....
This pic puts it all in perspective now... I get it...very nice!
F
fortbrick
Indiana
It's been a while since I've made an update...
Scheduled a date with the epoxy man to have him spend a day or two with us out here.
Excited for new things and warmer weather, which will hopefully come sooner than later.
fatboy99
Indiana
Great build !! You must be in the Fort Wayne Area with Home lumber and Speedway RediMix ?
BuickFarmer
Athens, Georgia
You're not fooling us! It will also make it easier to add the 24 foot Volvo Den in the future.:lol_hitti
Good to see you and your dad are working on this together. That lull with the deck must come in handy, would love to have one of those!
Will be checking back in, keep up the good work!
GRN96WS6
SOMD
Any plans to make a separate area for woodworking to keep the dust to a minimum?
dokebi1221
So....since you want to be an Audi tech, (I love Audi, I have S8) are you getting an Audi? Of course, it's for research purpose. ;)
F
fortbrick
Indiana
Yes, we live on the northeast side of Fort Wayne. The garage doors at front window came from Home Lumber. Menards had the same service door for around $150.
beautiful!
Thank you!
I'm working on putting together some signage for the walls! We were just talking about the possibility/ability of adding on to have some separated indoor parking and storage if we need it.
We are looking into what my father calls an "invisible sliding door" that might help out with this, but it is likely that we might move the more dust creating tools into the small garage and put up a dividing wall with a door in-between the two partitions.
Very Nice!!
Thank you!
Funny you should ask that.
I currently daily a '98 saffron V70R (google that if you haven't heard of it), and I really don't plan on getting rid of that anytime soon... but I definitely wouldn't ignore the desire of getting my hands on an A7 and seeing what I could do with it. There's something about that car that pulls me in.
F
fortbrick
Indiana
Haven't posted here in over a year now, and while I would like to say that a lot of progress has been made, I must admit that not a whole lot has. In June of '15 we got about 8" of rain in 24 hours and our basement flooded, so the past eight months have been spent rebuilding that instead of furthering our progress with the garage.
Good news is, though, that the flooring and the brickwork got finished and with spring right around the corner we should be getting the electricity and insulation phase complete soon.
We decided to go with a base coat of an off shade of white (almost a light grey), and white chips.
And it seems that this is the only photo I have of the brickwork in progress. I'll get a finished photo one of these days.
Thanks for reading
-Andy
F
fortbrick
Indiana
Looks good so far but what is with all the wasted space in the ceiling?
We have a few ideas regarding the upper area. The trusses are rated for ~700lb per, so we should be well with our bounds to use it for storage at a minimum. We did not want a flat roof and were trying to have it match the profile of the house.
matt_i
SE Michigan
Nice design, I am a little late but it looks like it matches the house very nicely.
Relative to the trusses, there is an "attic truss" that one can buy/spec and its some amount of clear span open area in the upper center. Typically engineered to a "** PSF" or pounds per square foot loading on the bottom chord. Much beefier using 2x6 and 2x10s etc.
Sorry to hear about your flood. I was trying to build a footing at the bottom of the foundation trenches at that same time period. I think I hand excavated 5-7 yards of additional dirt after everything collapsed...
F
fortbrick
Indiana
Thanks everyone for the kind words. As for the truss design, it simply was not in the budget. We had also thought of a mezzanine, but that quickly added thousands of dollars to the project.
