you don't have enough length to get high torque using a stubby, that is basic physics!
I got a work around for that
Pry bar against a stubby to get a lot of torque in a tight spot works quite well...you don't have enough length to get high torque using a stubby, that is basic physics!
Pry bar against a stubby to get a lot of torque in a tight spot works quite well...Thanks for the info, I was wondering about that.I'm not a big Craftsman guy, but this set is hard to beat at any price...Made in USA. Doesn't include racks, but fit perfect in the Ernst stubby racks.
Best advice you can get on ratcheting stubbies. These are offset & reversible, and the guy at ISC is really cool. I told him I wasn't sure since everything else I ordered was USA Williams, he said these are the ones he has personally and loves them. Glad I followed his advice.
I got a work around for thatPry bar against a stubby to get a lot of torque in a tight spot works quite well...
ratcheting + open end doesn't make any sense in the first place! - which end are you supposed to break with? - Answer: Neither
- use an intelligent ratcheting wrench, one that combines BOX end with ratcheting!
otherwise, use a regular combination stubby and forget the ratcheting part
I'm missing your point. The Snap-On are radius ground at the bottom of the open end and the HF aren't, so what?
Adam, here are actual pictures of the HF 13mm wrench from the set. To me they look identical to the Snap-On.
You might have been led astray by the picture you took off of the Internet.
You forgot "In harbor freight" at the end of that sentence.Here's the real deal. To me, they look like every other combination wrench I've ever seen.
Personally, I very seldom use an open end wrench. I go for a socket first, if that doesn't work I fade over to a box wrench and if that can't cut it I guess I'll try an open end. But, that's just me.
I was following what both of you were on about until this. I don't doubt they doctor the images, but to look worse? Not sure this particular image is a good example of that, no it's not beautiful but what about it looks worse than the actual wrenches in the store?You mean the picture from HF's website that is on the internet? HF does that. They doctor the images they put on their website to make their tools look like ****. Then when you get to the store, you actually buy Snap On wrenches for $25. Cause they're all made in the same place anyway.
To those that own the Sunex stubby wrench sets, are the box ends offset for increased accessed and to prevent knuckle scraping?
Thanks,
Dave
