DARK AGE 53
- Joined
- Jan 22, 2005
- Messages
- 1,002
What do you guys think would be a good price for this lathe, https://www.flickr.com/photos/94611274@N04/ . He want's $250 but being the cheap person I am I'm thinking $175, opinion?
That is a very old lathe, and while it can do quite a bit, especially teaching, if you really want to produce parts, hold out for a more modern machine.
$175?? Geezzz .... you need to buy the seller a really nice Christmas present!
$175, YOU ****![]()
Big time.... You should let the guy bang the wife for that kind of deal.... (Not necessarily yours.) I don't throw out reverse wife bangs very often....![]()
There's a serial number on the ways near the tail stock. Then go here:
http://www.wswells.com/serial_number.html
Oh, and you ****...
It is late March 1928.
I think you did just fine, is it new with all the extra features? No, but it is still a pretty nice little lathe. My first was a 1947 version of this same SB. It was a change gear machine as well and it never affected my use of it, what did limit me was the work envelope, most everything I wanted to do was too big for it, ended up trading up, wish I had figured out a way to keep it while still getting the others.
Oh, the gears aren't 'extra', they are what you install to get a certain feed rate or pitch for threading. The chart on the gear cover tells you which ones to put where when the time comes. To thread you will also want a threading dial, but not absolutely a have to item.
There is a ton of info online about SB machines, here is my favorite site http://www.wswells.com/
You can also learn a tremendous amount by reading everything you can over on practical machinist in the SB forum, ( http://www.practicalmachinist.com/vb/south-bend-lathes/ ) go ahead and go back to the beginning and you will see topics on every part of these lathes and learn a bunch in the process.
Oh, do not take the headstock bearing caps off until you read the proper way to do it.
It is great that you got the counter shaft with it, I have seen those go for more than you paid for the whole machine.
Good luck and congrats,
Jason
Yeah cb, I would think a reverse bang would be for the OP to bang Tampa's wife, not the seller's![]()
