It's what happens when you type and drive!what's Ctafsman?
But I read on here that craftsman was the same as Snap on...?......
These are absolute junk. If you buy this, you'll end up owning 2 guns. This one, that cant do anything, and a 2nd one that can actually get work done.
If you don't want to move bolts, this is the one to get.
Are u talking about the composite they had by the holiday sections stuff? That one was rated at 400 ft lbs.. How bad could it be for $20? The husky I have is only rated at 350 and it's done anything I've needed..
i get paid hourly so i dont wanna move bolts,just look busy and make noise.thanks op.
Depends on what you need....I took lug nuts off of a coach today with my 1/2" Nitrocat after the crack spread up the side of my 3/4" drive impact socket I was using on an Ingersoll Rand 2141. Same lugs and wheels as a semi truck. Not many 1/2" impacts that will do that, there's a few out there, but not many. It's really nice to have the torque when it's needed. I started out small years ago, and hated that weak wrench, got stronger and stronger ones and never looked back.
I've heard good things about the Nitrocat and AirCat impacts and have thought about pulling the trigger on one. (Pun intended). Bought a Craftsman 1/2 drive many years ago and never thought it was very good since it struggled with lug nuts I could break loose with an average size breaker bar.
After reading the comment about Craftsman impacts, I will probably go for an AirCat or NitroCat and will probably be amazed the first time I use it!
The 3/8" is labeled as the strongest in it's class, I wonder if it would replace a bad 1/2" for average use?
http://www.amazon.com/dp/B007WQQ90A/?tag=atomicindus08-20
http://www.amazon.com/dp/B002YKBJ8Q/?tag=atomicindus08-20
So what a decent gun for those of us that don't use the air gun every weekend? $100 or less? I haven't seen any cyber week deals worthwhile for air tools
Seems like a lot of folks like the AirCat and NitroCat. Think that will be my choice but not sure if I want the smaller 3/8" for easy access or the 1/2" for bigger suspension stuff....![]()
Snap-on's impact will
IR titanium will
