There is a growing use of belt grinders and sanders in lieu of the older grinding wheels. In addition, there is a DIY community of shop-made versions. Some are restorations or upgrades of vintage machines, while others are made from adapters or even from scratch.
They deserve their own thread. Show us what you got.
I'll start with an old Foley 1-inch belt sander that I recently renovated. It was a filthy mess that i bought from an estate with no motor, but it had a base and table so it was worth restoring. I ended up replacing the arbor assembly as the shaft was too short and I could not disassemble it. I made it from pillow block bearings and a scrap ground shaft. I also replaced the upper idler wheel bearings, as well as fabricating a new 2-inch rear idler wheel. Made a new drive wheel from Delrin while I was at it, and thought I was just about finished...
I put it together and found that this was a 1x44 machine, NOT the usual 1x42. So I opted to chop the upright tower to accommodate 1x42 belts, and now it works great. I only had a 1750 rev motor on hand, so I added a multi-speed pulley to bring it up to contemporary belt speeds as well as having the option of slower speeds for knife sharpening/sanding/polishing.
This is a handy vintage machine very much like the old Delta/Rockwells. I think the table and motor mount is better on the Foley, but everything else is pretty much identical. Excellent choice for any home shop.
How about a 36" grinding wheel...
