Coyote556
Gentlemen,
I had to run 10ga to many of the receptacles in the shop due to distance and voltage drop. I am using spec grade back wire outlets so the 10ga wire on the outlet connections is no problem, but on the ground screw for the outlets, the 10ga stranded is a nightmare. When I get to each box, can I use a 12ga ground pigtail to make things easier. I would like to pigtail off 12ga solid and attach to my 10ga stranded ground run. Is this legal?
Thanks ahead of time
