I may sound like a complete dummy by asking this, so bear with me here! I am a technician for a Toyota/Lexus and have been wondering lately about some possible usage of a SawZall rather than plasma cutter for a very specific task. Here's the scoop:
We have been doing complete frame swaps on certain trucks, mostly those that spent the majority of their lives to this point in northern/midwest climates and developed rusty corrosion and small holes in some cases. Obviously, as flat rate technicians, there are a few of us who choose to continually search and research new ways to be more efficient. It is much easier to try and take large chunks of the truck apart at once rather than piece by piece to prevent causing further, unnecessary parts replacement in the event of seized bolts and what not. Toyota actually provides us with new lower control arms allowing us to remove a SIGNIFICANT portion of the front end by simply CUTTING OFF the lower control arms rather than fighting the bolts out and cutting off the eccentrics. Now.. this poses an issue when it comes to more than one of us doing a frame swap simultaneously. We chose to save money on Oxy/Acetylene and buy a plasma cutter which has worked pretty much flawlessly, but waiting on another tech to finish cutting while you sit around is about as innefficent as it gets. To make a long story longer, would it be worth it to purchase one of the Milwaukee Torch Blades or another heavy duty blade of some sort for my SawZall and cut the control arms off? Will is cut through iron control arms without taking hours to do so? I am a SawZall rookie when it comes to anything other than wood, PVC, and other less-******** types of piping. Any suggestions are welcome!
