stormlover
Sorry to start yet another compressor thread but I'm considering a 40 gal. compressor because of space constraints. There are not many options. I could go 60 gal but I will have to either raise my cabinets or remove one entirely to fit. This is my dream garage and I messed up by installing all the cabinets at a 5' level last year and didn't account for the fact that most 60 gal. compressors are 63 to 70" in height.
Usage will be general bike and car repair (44x24 garage and bumpout for shop). Main tool usage will be impact wrenches and airing up tires. Sporadic use of a die grinder and pneumatic cut off wheel. Don't plan to paint & do not have sand blaster. The plan for piping layout is two dedicated hose reels on either end of the garage, an overhanging recoil hose over the bike stand, and another two or three drops for tools. At a minimum I think I need 10 or so CFM at 90 PSI.
This two-stage 5 HP Puma will fit but is $200 or $400 more than a single-stage 60 gal Puma or Quincy. I realize you really don't get into the quality stuff until getting into the 2K tier models. http://www.aircompressorsdirect.com/Puma-TE-5040V-Air-Compressor/p13941.html
Model Number: TE-5040V
UPC: 636084028571
Manufacturer: Puma
Motor
Running HP: 5 HP
Voltage: 208-230 Volt AC
Phase: 1-Phase
Amp Draw: 23 Amps*
Recommended Breaker: Consult Certified Electrician
Pump
CFM @ 90 PSI: 14
CFM @ 175 PSI: 12.8
Max PSI: 175 PSI
Pump Material: Solid Cast Iron
Pump Type: Two-Stage
Pump Drive: Belt Drive
Oil Type: Oil Lubricated
Oil System: Splash Lubricated
Low Oil Shut-off: No
Oil Sight Glass: No
After Cooler: No
Tank
Tank Size: 40 Gallons
I could go with the 3HP motor and save $150 but my thinking is with the lesser storage of the 40 gal tank, the 2 stage will recover faster. Does more HP trump bigger tank size? That is, once you hit continuous demand tank size is irrelevant because the pump will only make so much air. Everyone recommends going big with tank size but that's partly because larger tanks give smaller compressors and motors time to recover. So, I guess the main question is whether or not the smaller 40 versus the 60 is a deal breaker for my application?
For example, will I blow through a 40 gal tank simply blowing leaves off the driveway?
UPC: 636084028571
Manufacturer: Puma
Motor
Running HP: 5 HP
Phase: 1-Phase
Amp Draw: 23 Amps*
Pump
CFM @ 90 PSI: 14
CFM @ 175 PSI: 12.8
Max PSI: 175 PSI
Oil Sight Glass: No
After Cooler: No
Tank
Brilliant
