Scsmith42
Wow! This thread is a prime example of why folks who don't know exactly what they're talking about should refrain from giving out advice. Two pages of assumptions and confusion.
Bottom line:
A 50A RV circuit is a 120/240V, 4-wire circuit. It's not "120", and it's NOT "240". It's 120/240V, using two hots, a neutral and a ground.
A welder is typically a straight 240V circuit. Two hots and a ground.
YES, you are correct. You can use your welder on your RV circuit using that exact adapter. You can also just replace the plug with a 14-50P plug and ignore the neutral prong.
Amen....
Scott
2 hots (or 3 if 3-phase wye) sharing a neutral IS a MWBC....not sure what youre talking about...
