I have started building my first home and it will have a 20' wide by 44' long drive through garage. Of course, I'll never have a clean enough garage to actually drive through but since it is on a steep slope, I have to limit my garage width since I'm terracing the hill side. It will have a garage door in both ends which will be different.
I hired a crew to build the retaining wall and a storm shelter using Symon forms and now I need to prep and water/damp proof the concrete walls before I back-fill. I have googled this topic to death and have come up with so many ideas and opinions it is confusing so I am hoping some of you can help guide me in the right direction. The concrete guys I hired do not do water proofing so I'm looking for some ideas.
I believe the general process for water proofing is:
* prepare the walls by sanding/grinding the surface to remove all delaminated plywood, paint, grease and ridges from forms, as well as any other surface defects
* fill all bug holes, snap-tie cavities and low spots from form seems to make the surface smooth
* apply an elastomer coating to seal it (any recommendations on which brand/type?)
* optionally add membrane to protect the waterproof coating
* optionally add foam board for thermal break before back filling
* install french drain, wash rock and geo-fabric before back-filling
Does my water proofing list look reasonable or is there something I'm not considering?
This is my only chance to get this right so I need to take my time and figure out exactly what I need to do before tackling it.
And for everyone's enjoyment, here are the obligatory pics to accompany my build. All concrete walls and storm shelter roof is 8" thick with #5 rebar @12" horizontal and vertical. The storm shelter roof was poured monotonically with the walls so it is one seamless box.
Concept drawing of the house and where the storm shelter is located under it...
Garage view...
Garage view...
