Askme42
Think I'm ready to take the leap and get some. Probably not willing to spend snap on money.
Recommendations?
Recommendations?
(both the Facom fine tooth and standard are discontinued)SK. The original.
I found a NOS fine tooth model (the TUFF 1/Facom design) at an industrial supplier a while back and like it quite a bit. They can be found on EBay but sadly they are not currently being made.(both the Facom fine tooth and standard are discontinued)
With that said, the HF ones click very loudly, some love them and some hate them, but if you don't mind having some green handled Pittsburg ratchets in your box its probably a good way to go, try them out and see if you like using a roto ratchet and then upgrade to something better if you like. Sounds like Carlyle (Napa) makes a nice one too.
I read a lot of bad things about the tough one. Something with the screw either being too tight or loose all the time.
Yes the tension on the screw must be set properly and you need to use Loctite, but when they're set up right they are REALLY nice. I absolutely love mine and grab my 3/8 tuff one over my Snap-On dual 80s. It just feels right and smooth. I put loads of torque on it and it never slips or reverses either.What is your realistic budget?
When I was shopping for Roto's I first looked for a SK in good used condition, but they were priced like gold on ebay. I then read up on the Gearwrench and they had a lot of negative reviews. The Carlyle seem to get decent reviews, but I've never had my hands on one. The HF felt like **** and I wouldn't consider it. I ended up buying an FHNF100 on ebay (brand new) for $65 shipped and my THNF72 (also brand new) for $66 shipped. So far, I don't regret spending the money for the Snap On's!
There's always going to be someone to complain...Yes the tension on the screw must be set properly and you need to use Loctite, but when they're set up right they are REALLY nice. I absolutely love mine and grab my 3/8 tuff one over my Snap-On dual 80s. It just feels right and smooth. I put loads of torque on it and it never slips or reverses either.
I have the Husky models, they work REALLY well. They might not be as well built as SK/Gearwrench but they get the job done! They also don't have the back drag that the Harbor Freight models have which is a plus. The only problem is I don't think the stores carry them anymore.
Recommendations?
If you only think you are ready, test out the idea with the HF for $12 after coupon. If you like the idea return it before the 90 days and put the $12 into a good one.
is scandalous and bad, bad tool karma.
The Home Depot by me still has them. As said, the backdrag is definitely better than the Harbor Freight, and they don't have the goofy *** handle.
I only use a roto in 1/4, so no issues from me with a HF.
No idea what sort of magic you are expecting from a Snapon for 10x the money.
The ability to oil and inspect the internals of the ratchet for one. Also the ability to adjust the tension yeah the price is a stretch but it does fill a void in offerings because no one else has a usa made version.
cornwell??
mac?
Same Taiwan made 100 tooth as Cornwell and Carlyle.mac?
