Hi all. New here and love the forum. Im starting my 28x40 shop next week and have been planning for months. The shop will be used to store boat, snowmobiles, and a 1/2 ton pickup and then shop area. Im going with radiant heat and wanted some suggestions on the installation. I live in Iowa so the winter months are pretty cold.
Is the DOW blue board (25psi) 2" thick sufficient enough under a 4-5 inch slab? Or should I try and find 40 psi high load. Im having trouble finding the high load and would have to special order. I can get the 25psi for $21.70 a sheet.
Ive been looking at radiantmadesimple.com and like the ease of a preassemble system. Cost is $2000 for the system and about $176 for a 300' roll of 1/2" pex. I would need 3 rolls. Has anyone had experience with their systems?
What kind of vapor barrier do you typically use under the foam insulation?
The concrete guys want to use rebar on 4' centers so I would need to put 6" wire mesh on top of that to ziptie my pex to. Any suggestions would be greatly appreciated. I will be posting pictures soon to document the build.
