Hanging Some Glads
Zrexxer
Pflugerville, TX
Well, it took me awhile, but I finally got sick of walking around the Gladiator wall cabinets I'd bought, ummm, about 10 months ago...
I knew where I wanted to hang them, but I had to have a plan in my mind. Since the woman is in New York this week with her daughter, it gave me time to get it done.
They were intended to go into an alcove between the water heater closet and the outside wall that's 88" wide, but it's an interior wall and the studs are 24" OC.
So, one cabinet was only going to catch one stud. For the same stud spacing reason, I didn't want to use geartrack. So, I bought some 1x4s and mounted them across the entire width of the wall with 2-1/2" ITW screws, thereby picking up both corners and three studs in between.
The vertical pieces are intended only to close off the space behind the cabinets, so it doesn't become a den of spiders and insects. The center piece was really unnecessary, but I had one piece of wood left just that size so I put it in anyway.
Now, being the misanthrope that I am, I was hanging these alone, and I had to figure out how to get the cabinets over my head, and hold them in place while I lag-screwed them to the 1x4s. Without having to grow an extra pair of arms, of course. Digging through my stash, I found a piece of aluminum channel that looked like it would solve my issue.
I screwed the channel to the studs flush with the bottom 1x4, and voila! I had a ledge that I could set the cabinets on while I secured them.
Now it was just a simple matter of lifting the cabinet up onto the ledge and sliding it into place, then using a cordless driver to secure two screws.
Once the cabinets were secured, I just unscrewed the temporary aluminum ledge and the job was done. There is going to be a built-in bench go underneath these... eventually.
Dan in Pasadena
Pasadena, CA
Good job!
May I make a suggestion? How about filling the spaces on each side of these cabinets with a couple open shelves? You could paint them in a silver to match or even use aluminum to give the appearance they "go" with the cabinets. Maybe you don't want anything exposed? I get it, but just an idea.
Z
Zrexxer
Pflugerville, TX
Good job!
You read my mind!
The ultimate plan is that there will be a bench full width underneath them, as mentioned. Then, from the benchtop to the ceiling, I'm planning on building open shelves on each side of the cabinets. Funny you should mention the color, because I was thinking of painting the uprights a dark grey to blend with the cabinets, and doing the shelves silver.
Z
Zrexxer
Pflugerville, TX
My sketch-up looks more like throw-up, but this is kind of what I have in mind. At this rate, it shouldn't take me more than about 12 years to accomplish...
Dan in Pasadena
Pasadena, CA
Can't wait to see how it all comes out.
I was thinking of something a little simpler. Yes absolutely on the bench across the bottom but I was thinking of shelves without the uprights, without a face frame. I was thinking of shelves that attach at the walls on the sides and the cabinet sides in the center. Just an idea but it'd require less materials.
