Wired/Cordless Impact Drivers
CobraKramer
Can anyone give me some insight into a good wired or cordless impact driver? I dont have room in my garage for a air compressor but would like to use something to (besided wrenching) when I have to bolt up items or take them off. As far as I am concerned it doesn't have to be cordless, but that would certainly help. I have been looking at sears only b/c I have a gift certificate from the mrs. I have yet to use.
Thanks
back2class
Waste of money! I have never seen a elec or cordless impact that could generate more power than my hand an a short 10" breaker bar. (I am only 5;5" and 150 lbs.)A truely useless tool unless you are doing huge amounts of production or rare times when taking a bolt off a shaft that spins and you can not brace.
My guess is you want an impact for power. The electrics do not have any. TOTAL WASTE!
vette-kid
Navarre, FL
I saw some of those the other day and was curious so I did some reading. At most they make about 100ft-lbs of torque...not a whole lot.
sjt78
Western NY
Milwaukee makes a few very nice corded and cordless impact wrenches. I have a corded one (model 9072-22) with variable speed that is rated at 100-300ft lbs of torque. It has removed every stubborn bolt for me so far.
Monte
Germany
Fein ASB 658-1 ... 516 ft-lbs. :)
rsanter
visalia ca
I have a dewalt corded 1/2 drive impact
works good but not as good as my SO or Mac air drive impacts
it will get lug nuts off no problem
bob
C
CobraKramer
What am I missing then...this model that I have linked to is a simply craftsman 19.2 Impact driver. The stats are listed below...given the torque specs it seems high to those referenced above?
Powerful 19.2 Volt - provides maximum power for drilling and driving needs
1/4-in. Metal hex coupler - for quick bit changes
900 In/lbs. torque - for superior driving performance
Die cast gear case - for added durability
Forward/reverse switch - conveniently located for easy bit direction change
Braking switch - stops coupler quickly for easier and quicker operation
Built-in LED - improves visibility for improved illumination of work area
Mid-handle design w/Firm Grip feature - for balance and added comfort
Bo Heck
You're taking about an Impact Driver while others are discussing an Impact Wrench.
Stats are not high, you're seeing in/lbs torque, Impact wrenches are measured in ft/lbs.
MattPersman
Indiana
I have the Dewalt dw059 works pretty well for a cordless, my friend has the 14.4 snap on CT4410 also a nice piece, the ct4850ho would be the cordless of choice if I worked at a salvage yard or was a mobile mechanic.
I think a corded impact will give a better bang for the buck, most popular brands Dewalt, Ridgid, Milwaukee, Makita, etc will offer something that is over 300 ft/lbs
gibbon_guy
Redmond, WA
The snap-on 14.4v cordless impact wrench is really really handy. The torque claims are not as high as they say. The snap-on salesman that we deal with said it could take off a lug nut on his truck...I can barely get one off at 90 ft lbs
[edit] for terminology [/edit] thanks ;)
Bo Heck
The snap-on 14.4v cordless impact driver is really really handy. The torque claims are not as high as they say. The snap-on salesman that we deal with said it could take off a lug nut on his truck...I can barely get one off at 90 ft lbs
You mean wrench?
