75gmck25
I insulated my basement's concrete walls with 1" XPS foam and then framed a 2x4 wall in front of the foam. However, the concrete slopes back some at the top, so at the top I have at least 1" of space between the 2x4 top plate and the XPS foam (which is right against the sill plate).
I know I need fire blocking to close off the space between the top of the wall and the sill plate and I'm looking at alternatives. Some folks use OSB, while others use drywall. However both of those are relatively hard to nail or screw in place because I have only about 10" clearance between the sill plate and the floor above. Its also a lot of cutting and filling to put a filler piece between every floor joist, and I will have to work them around the gas line and plumbing lines that go down into the new framed wall.
I've also read that it is acceptable to close the space at the top off with spray foam, but I don't know if I need any particular type of foam (e.g. fire retardant).
Any recommendations on fire blocking methods for the top of the wall?
Thanks,
Bruce
Thanks,
Bruce
