bmw57isetta
Hello from Central Texas! I recently bought a new house and, among other things, gutted the garage, installed second subpanel, added multiple outlets for equipment, audio, video, Internet, compressed air, etc. All circuits are 20A. Reputable electricians did the work and everything tested fine.
I have an eight year old Craftsman shop light. It's the extruded aluminum housing with two 4' T-8 bulbs. It's worked flawlessly in two previous locations although they were older houses with no GFCI outlets in the garage. The new garage has two, one for each main 20A circuit.
Any time I plug the light in and turn it on, it trips the GFCI breaker. I had one GFCI removed and replaced with a new, hospital grade 20A duplex outlet and it works like a champ at any outlet on the non-GFCI circuit. I also have a completely restored '50's Craftsman 150 drill press that would trip the GFCI breaker every time but never on the non-GFCI circuit.
I replaced the switch in the shop light with an exact replacement, no difference. The electronic ballast is original and appears to be fine. Sometimes, if I turn the light on, breaker trips and I reset it, the light comes on fine but if I turn it off and back on again the breaker trips. Then it won't reset at all if light is still in "On mode". What could be the problem? I'm at the point of having the second GFCI outlet deep-sixed and moving on down the line.
Any GJ wisdom will be appreciated. By the way, I'm no electrical guru and all work has/will be done by a licensed electrician.
