Haven't even powered it up yet. Later this morning I'll see how it goes.
Not sure why there are two speed controls. Maybe because the one on the motor is so difficult to reach while working?
I'd be curious how do you go about setting up the belts/pulley ratios with that variable speed motor?
Can you leave the belt/pulley ratio 1:1 and let the motor do all the speeds?
Or do you need the mechanical advantage of various pulley ratios to give the motor the required torque vs. speed?
The idea of a DP with a simple "turn the knob" speed control is intriguing. I know some guys have used 3 phase motors and a VFD and others have retrofitted used exercise machine motors. I'd be interested if there's a simple bolt on VS 120V motor for a DP that eliminates the need for belt changes. (full torque at low speeds seems like it would be an issue).
