Thanks to all for the awesome suggestions!
Note to
Drivesitfar and Rock knocker: I am having a little bit of difficulty uploading the pictures because I have a very slow computer and when I attempt to select the photos to upload it goes into a dark hole in cyberspace!?!?!?!
Please forgive the length of this post, but I am attempting to respond to several posts at the same time.
The model number of my saw is 113.240421 and it was manufactured 10/75. It belonged to my dad who is now deceased (miss him a lot for advice, chats, etc.). My goal is to upgrade the saw, and the difficulty I am having is in trying to decide which upgrade would suit me best for the money. I doubt I will choose the Biesemeyer even though I see from the many details it is probably the best on the market. I have located a
Vega U50 Table Saw Fence System: 36-Inch Fence
that I am considering purchasing. It is a bit pricey as well as others, but not as much as the Biesemeyer.
Note to
dale500: I searched thoroughly all the Sears stuff and they have no information on this original fence, all information shows it and the parts are no longer available, and that was when I made the decison to search for other options. At the end of the day, what I am seeking is a much more precise setup that does not require double checking every measurement front and back to ensure the cut is square that is easy to install and won't send me into bankruptcy.
The Vega fence mentioned above is priced at ~$250.00. I have also found some older Delta and other higher end used fences, but the details are incomplete and not sure if the additional research will be enough to make a decision.
Note to
foghorn1966: I have been considering the Delta fence and have found some online, but have not had ample time to research installation steps. Is that fence easy to install? Does it require front and rear mounting?
Note to
retfr8flyr: Good suggestion on the Incra fence. I will research it. Does it have both front and rear mounting? Is it a precision fence in the category of the Biesemeyer style, i.e., quick setup and accurate?
Note to
gungatim: Can you tell me more about the unifence? Is it a front mount only, accurate setup?
