superskaterxes
So im looking to heat my garage to be able to work in it during the winter and i have explored several options but im not sure yet what i want. I have gas available but i dont want to have to run the vent setup for a blower unit and i heard horror stories about the moisture buildup in non-vent setups. Right now im using a Mr. Heater propane heater similar to this and it heats the garage up very well
electric is out of the question because its expensive and inefficient. Here are my garage specs:
22x22
3 walls and roof are insulated
BTU calcs come out around 22-25k which is what my propane heater puts out and it only needs to run for about 10-15 min before the whole room is hot.
I then came across the hydronic unit heaters which make alot of sense to use. I know they are designed for a boiler system but i cant find a reason why they would not work with a regular water heater.
http://www.modinehvac.com/web/Hot-Dawg/Hot-Dawg-H2O.htm#.VJsIoV4DYU
I currently have my water heater set to 120*F which is the minimum the hydronic unit can run at. My idea was to take the output of the water heater and feed it straight into the unit heater in the garage and then out of the heater into the rest of the homes hot water system.
the unit heater has approx a 14-20*F temp drop over the coils so if i were to raise my water heater to say 130-140*F i would still be getting 120*F at the faucet to avoid burns. I would turn the water heater back down to 120*F in the spring/summer/fall when i dont need the garage heated.
does anyone see a reason this wouldent work? it sometimes dips below freezing here but very rarely so i dont see the pipes freezing especially if they are in the garage. I have attached a picture to explain what i was thinking.
The only downside i can see is the pressure drop over the coils which is approx 4-6. Here is a link to the model i am looking at which has a chart on page 9. I am looking at the 45 size unit.
http://www.modine.com/download/1/1-500.pdf
ultimately i would like to be able to run a closed loop system with a coil running through the hot water heater but i will have to wait for my current water heater to die first =D
22x22
