I have a Ridgid 18v Max 2.5 Ah battery that did not charge anymore. I took the case apart and found there is a fuse tab between two of the batteries that is blown.
I connected the two halves of the fuse with a test lead and put it in my charger and it charged, but the wire on the test lead burned. I tested the voltage in the battery and it is around 18v. I put the battery ion my drill and the drill worked, (I didn't use the drill, just turned it on).
I am curious about the fuse though. Why do they blow in the first place and was the wire on the test lead too thin and burned, or is the battery toast?
If the battery is still good, what can I use to fix the fuse?
Thanks,
Ian
Thanks,
Ian
