Weather pack crimping problems
Whiskeymike
Austin, TX
I'm trying to use a new tool-aid crimper http://www.amazon.com/gp/product/B000K1CFXO/?tag=atomicindus08-20 and having quite a bit of difficulty.
There's a slot that the weather pack connector fits in perfectly with the multiple widths of the connector. However, when I crimp, it spreads the flanges apart instead of crimps them. If I put it kind of sideways like in the picture, it rolls it and crimps it kind of half assed, but better than other way. Not very repeatable.
Do I have the wrong tool, or am I doing something wrong?
ImageUploadedByTapatalk1419724256.021697.jpgImageUploadedByTapatalk1419724267.697849.jpgImageUploadedByTapatalk1419724279.140181.jpg
Strouty
Southern Maine
Try putting the crimp ears into the hollow part, then the crimper would roll the tabs instead of spread them.
QtrHorse13
TX
Are you sitting the connector in the bottom crimp jaw (bottom in your pic)? Are you putting the larger part of the connector in the wider portion of the crimper jaw?
Just in case.... You are sitting the connector in the raised section (raised section on the bottom crimp jaw in your pic) of the crimp jaws, correct?
QtrHorse13
TX
They are the right jaws. He is either putting the connector in the U shaped section on the bottom or upside down in the correct section.
pmilin
Colorado
The jaws will crimp the wire ok but they will mangle the tabs that hold the seal.
QtrHorse13
TX
My Ideal multi jaw crimper works great and it looks just like the one he has. The crimp jaws have a wide and narrow side (left and right). You have to install the larger/ wider part of the connector that goes around the rubber grommet in the correct/ wider side.
redmondjp
Redmond, WA
I used to design heavy truck wiring harnesses, and bought a genuine Packard crimp tool while I was there. Mine is a single-width which requires that I do the wire crimp and the seal crimp separately. Sometimes I've found it useful to slightly pre-bend the tabs down on the wire seal in order for the crimper to crimp it properly.
Some of the aftermarket crimpers may have slightly different dimensions than the OEM ones, and it doesn't take more than a few thousandths' difference between a good and bad crimp.
