theoldwizard1
I must be missing something. Sure seems like a big expense for only 525 watts.
times 24 hours per day time 365 days per year is 4.6 MEGA watt-hours per year !
Next year i'm planning a dam to build a big "water battery" which will store ~30 days power![]()
I would think this would not be too much of an issue with constant flow. How many GPM ?you got it OldWizard-- small amounts of continuous power compounding over time-- far out performs our much larger solar array (which "Peaks" at 3,000 watts at noon, but seems to be a pretty poor performer at 3 am )
Here are a few shots of the generator its self:
*Looking at the 4'x4' insulted building (needs to get leveled and moved another 30 ft down the hill.
*Looking into the building; manifold of PVC; 3x 3/4" 12 V DC electrically actuated ball valves.
*Pressure gauge showing current pressure
*Temp gauge showing current water temp (very important!!!)
Very cool !*there is a micro controller in the center that communicates with a local cell tower. Essentially I can "text" this unit and say things like "valve 1 on" and it will turn on, etc. Saves me a half mile hike when I need to change out-put based on demand or stream flow.
$$$$I ran 2500 ft of 6 gauge three strand direct burial AL.
I'm not EE, but wouldn't there be less loss with AC over long distances and rectifying it "up the hill" ? (This was the big argument between Edison and Tesla.)Its currently running @ 120 V DC (w/ two wires tied together on - side). The hydro produces "wild" three phase AC which is rectified at site. I could send the wild three phase up the hill and rectify right before the charge controller. I don't think this buys me anything, though. Charge controller at charging shed takes sets the power point (105 VDC, 15 VDC is lost to resistance up the hill) and then charges the battery bank.
What brand and model of turbine, generator and inverter are you running ?A 3.6KW inverter feeds everything else.
This is version 6 or 7 and is starting to work pretty well. (Version 1.0 was 12 V, very basic short hydro, and a car style square wave inverter).
I'm flowing ~ 40 GPM right now; I also thought it wouldn't freeze,but last winter when it dropped beneath 0 F something froze... and then it backed up and everything froze splitting 800' ft of 3" PVC pipe (!!! ).
I have 1/3 of the line buried now ( w/ 1" insulation on top of line). the other 1/3" is 2" pipe so the water is moving faster, and its fingers crossed for the last 400' ft of pipe![]()
TRUE !I am not an expert or even a beginner.
I thought originally AC and DC power was distributed in the US. AC won because there was less power loss than DC.
