Most Used Wrench
redmed
The wrench you grab when walking over to a task for the first time.
I always grab my 9/16x1/2 box end.
scw1991
my most used wrench is the correct wrench for the application.
txdude87
+1
There is not a lot of situations that are exactly like the last one. For me it depends how snug the bolt is as to what I grab. My 3/8 socket set probably gets the most use.
joel63
Central FL
I have the 3 piece set like that that I bought over 40 years ago.
I sold almost all my Craftsman tools a few years ago, but I would never part with that set.
Very handy wrench set.
:thumbup:
Smokeshow69
Most used wrench is what ever is most correct for the job. Usually I have my double box end p&c 1/2 and 9/16 handy or my plvmb offset box end 1/2 and 9/16 handy. They work for most of my projects.
shockwave
Marietta,ga
I use my 12x14mm deep flex head mountain spline ratcheting wrench the most from anything tot belts and brakes
Dustball
Hudson, WI
I just had a genius idea- I may even do it too!
Buy a full set of cheap metric and SAE box wrenches. Cut all of the box ends off so you're left with just the ring portions. Mark/engrave the sizes on each one and store them on a carabiner or ring of some sort.
Take the collection with you to the bolt/nut in question, find out what size it is, and walk back to your tool box and get the correct wrench or socket.
Dr.JohnnyFever
A lot of my adjustable wrenches have a scale on them. If I am going to have to scout it out ahead of time, I just take an adjustable with me.
wild cowboy
Birmingham
10mm ratcheting double box - one end is ratcheting and one end is a box end (i.e. it makes sense, unlike the gearwrench combination wrench, which makes no sense)
R
redmed
:thumbup:
I agree that wrench is very handy. I wish I had that 3 piece set. I only got that wrench. Bought that wrench when I was fixing my car while traveling on vacation and had to get a few extra tools.
VictorBravo
Asotin County, Washington
I look at the fasteners first, the go get the wrenches I need. My HS shop teacher 40 years ago would give us pop quizzes by holding up a bolt and demanding to know the wrench size. That's stuck with me.
DJAMiller
Florida
I always grab my metric snap on wrench roll up pouch, has 8mm to 19 mm in it, all I ever need 99% of the time and the pouch means I have them all right there and ready to go, no looking through the drawer for the size I need.
67King
Friendsville, TN (Knoxville area)
10mm ratcheting combination wrench
90% of the time
Yep. Often in tight spaces, I'm often taking off more smaller stuff before I start getting into the big stuff. Can't access M6 fasteners with a bigger tool, as well, so if it is indeed a wrench in question (and not tool in general), then it is the 10mm ratcheting (and in my case, the reversible, as I have a few different styles).
Pumpman1968
Upstate, NY
My Craftsman 10" adjustable....it's in my pocket every morning. This time of year it's a boiler check first thing....and the adjustable and waterpump pliers go with me everywhere.
Deadhead
Northeast Arkansas
I would not know how to act if I could answer that question. I suppose if your a specialized tech (say front end or transmissions) you would use the same 4 or 5 tools all day long.
With what I do, some days its a multimeter, some days is a 32mm impact socket. The list of tools needed to pull a fuel tank and change a hydraulic suspension cylinder is 14 to 15 different sizes of wrenches and sockets and I have done several of them lately but I may not do another one till April.
Some times I feel like I throw half of box at a job.
Most used? all of them
MrJason
Bakersfield, CA.
I've noticed that for my racing team, we grab for a constant wrench in the midst of all others.
9/16 x 5/8 Dbl Box Wrench
Alternatively, the second most requested wrench is a 5/16 x 3/8 Dbl Open Wrench for adjusting barrel valves or magneto adjustments.
nicksnothereman
In the Mojave
OP is doing a specific job probably. Kind of like the first p2 driver you reach for.
Wrench wise for me (not that I work like this) it would have to be a six point craftsman raised panel if I have my wrench bag on hand otherwise the same thing in craftsman industrial black (armstrong) 12 point. Love those industrial wrenches.
