Debris in air tank
TheClaw
Chicagoland
I scored a decent 60gal vertical compressor tank (instead of having to buy a new compressor). It's was sitting around in the PO shop for a ling time. As we moved it I could hear some debris shaking around the bottom. I could likely vacuum it out provided I can open one of the plugs. I've treated rusty gas tanks on my motorcycles before but I was wondering if there is a similar treatment for larger air tanks.
Thanks,
Jeff
GRN96WS6
SOMD
Sounds like rust, they hold a lot more pressure than a gas tank, might not be wise to air it up if so, if it explodes that won't be pretty.
T
TheClaw
Chicagoland
Agreed but no reason to believe this tank is anything but solid. A little rust is not that uncommon, no? Just wondering if there's some maintenance that's worthwhile before I mount the motor and pump.
DekeT
USA
I would never put a tank in operation that I did not thoroughly inspect inside and out. I take the opposite POV that there is no reason to believe the tank is solid.
GRN96WS6
SOMD
You'd have to inspect it inside to see how bad the rust is.... I think they all rust but if it's too bad and explodes that will be deadly.
Doctor Bill
South Arkansas
They are actually putting a "Discard After" date on portable air tanks for this reason now. Had a relative killed by one that exploded a few minutes after being filled. An old machinist gave me this static test method: You fill it completely with water (all air out) cap it off except for a pressure gauge, release valve, and a grease fitting. Use the grease gun to bring the pressure up to a test point maybe 150% of working pressure. Let it sit for a few hours at that pressure/temperature to prove it is sound. Having a hydrostatic test done , possibly not that expensive, also may be an option...
kbs2244
I have heard of guys useing a pressure washer for testing tanks.
Plumb it up, put it around the corner, and turn it on.
T
TheClaw
Chicagoland
Ok, dumb question, when I'm using a grease gun to pressure test the tank I use an empty gun, right? Or does the grease just drain out with the water?
Hornman
Southwest DFW
Plumb up a horizontal run of pipe you pump the grease into. It will stay in that horizontal run and not fall into the tank.
malbojah
Cape Cod, MA
Any suggestions on how to remove the big inspection plugs (3/4" square female plug) if they don't come off with an electric impact?
RossABQ
NM
Pressure washers operate at huge pressures compared to an air tank!
AndyA
Texas Near Dallas
I think the idea is you keep the engine turned off and just rotate it slowly using the pull rope. Stop pulling when you hit the desired test pressure (around 300 psi rather than 3000 psi or more where the pressure washer will top out). If you have an electric pressure washer, you're out of luck!
T
TheClaw
Chicagoland
That's the million dollar question! I couldn't get mine undone. The fittings were all wrong too. I was looking at alot of new plumbing.
I've already re-sold it and bought a new tank (at a real bargin price) to retrofit my good motor and pump.
Tronyadorable
I've already re-sold it and bought a new tank to retrofit my good motor and pump.
Ona mine is a left hand thread plug.
Indyducati
New Palestine, Indiana
Claw, I'm curious how you found a new tank at a bargain price. When I price tanks, they're equal to the price of an entire low-end compressor package !
Steve
sberry
Brethren, Michigan
You need a pressure relief when using a washer. You can use a valve to regulate it.
PT Doc
If I heard things rattling around in a tank, I too would question the integrity. After all, good tanks don't make noise.
T
TheClaw
Chicagoland
Steve
I bought my original compressor from this guy 19 yes ago when we was a small independent tools store. Before HF moved in. We have since moved out of the area but I went back to him to buy a new Puma. I told him that my tank was leaking and he said why about this? He showed me a new 60gal tank ticketed at $399. He said he let me have it for $275 to get it moved. It had the same fittings as my.old talk. The used one I'm cleaning does not. Needs a lot of pluming. Kinda hard to pass up a deal like that. The tank I picked up the other day is already resold
This guy has a great store. Some used a lot new and the new stuff is not the CCC (cheap Chinese ****) at HF. He sells alot of scooters and ATVs now but he's still in the same location on the wrong side of town. If the US made motor I have goes out or the pump goes out. I'll go back to him for spares. Even if its out of my way.
