Re: Show us Your Vintage ratchet before and after restoration!!!!!
Is that an old GM 671? What are your plans for it?
Not sure of the model or the year of it. It has "T 2 46" stamped on the back and there is a circle H on the head. I can tell you that it's 1/2" drive and it was rather nasty inside.
Wiped all of the old grease out with some shop towels, then blasted it with some brake clean. Did what I could with various wire wheels and some metal polish.
I haven't lubed it yet as I am awaiting some Super Lube to be delivered.
Edit: Poor lighting makes it look less shiny than it really is.
its like my ratchet in the previous restoration project![]()
I'm sure you will make it like new![]()
These restorations are very impressive! I have one of the Craftsman BE 1/4 open ratchets in one of these earlier postings; it is missing the spring. Is it possible to replace the spring without too much work or damage? The ratchet is riveted, and I have no idea what size spring it takes. It would be nice to restore mine to a useful life as well. Thanks!
hi
you have to remove the rivet and you can get any modern 1/4 craftsman repair part and take the spring and pulley ball then put them there
Those are my all time favorite style of ratchets. They are the ones I grew up with. The Butterfly selector (the official name used by Craftsman) was only offered between 1960 to 1964 when the selector was changed to the Long Lever.
These have also been called (by the public) "Flying V", "V", and more recently the "Star Trek" selector.
If the anvil is bare metal (like your's), it is original. If the anvil is black, it was from a rebuild kit.
These are the first ratchets I collected and rebuilt. I have a flex head 1/2" and 3/8" also. These are the ones I've had trouble finding clips for as the diameter of the V lever is different than the plain lever.
The after is easy to imagine, as I already shined up the handle.
This is the before. All that junk on the paper towel to the left? That's what I had to chip out of the retaining ring groove in order to compress the ring enough to remove the core. This thing must have sat in a bucket of silt for years. It was frozen solid, and took 3 days in solvent and a lot of manipulation to free up. After some TLC it purrs like a kitten.
nice job
believe me if you use paint thinner and dremel rotary tool ,you will not take time to remove old grease and grime .in your case i there is a lot of rust inside gear housing ,you can use eavpo rust remover for 4 hours and after each hour take the ratchet out and use small wire brush to make the rust removing process more easy .after that wash it with water then wipe it after that use Turtle Wax Chrome Polish And Rust Remover to clean chrome surface![]()
i am looking also for the flex head to complete my V ratchet set ,
which clips you are talking about ?
NO, do you have?
nice job
That was actually the old dried grease and grit. A few days in my solvent mix, with breaks to try and free the mechanism of the dried grit that locked it up and it came out nice and clean. No need for a wire wheel.
My mix is somewhat more aggressive than paint thinner. Requires gloves, mask, etc. It's very nasty stuff. But it dissolves everything not made of metal in short order.
So my latest resto for my collection I found the same day as the Plomb I posted a few days back... a Proto 5450 1/2" drive long handled rat.... nearly 16" long! Here it is, how I found it, in the bottom of this tool box:
wooooow that is really big changea Proto ratchet its really tough we use Proto tools in our steel plant
