Jawn
I went to the basement / garage this morning to find puddles covering much of it. It seems my drainage issues have bitten me in the **** because of an overnight gully-washer.
Part of it seems to be coming from this poorly drained area. For the area between the driveway (concrete in foreground) and the AC unit, I was thinking of either digging a shallow swale with a drain grate embedded in the bottom at one end, or else putting a trench drain in. Which do you think would work better, or do you have a better suggestion?
Surrounding topography is level to the right for about 10-20 feet, then downhill. Behind the camera in this point of view is also downhill and likely a better route for a drain outlet since it wouldn't have to dump into the yard.
