Bench Grinder inspection
Faisal
Saudi Arabia
hi everybody
today i bought online Vintage Craftsman Bench Grinder model N#397.19581 and i am waiting for it
my question is
what i have to inspect and what is the preventive maintenance i have to do with it ?
its my first Bench Grinder :D
thanks
454ragtop
Carver, MA
Plug it in and turn it on. Not much to go wrong with those, and that one doesn't look like it was abused. If it makes no strange noises you should be good to go. May have to dress the wheels if there is vibration, not a big deal.
Good luck, Jim
Davefr
OR
It looks like the ground pin was cut off the plug. (that's not uncommon on these old tools).
Add a new 3 prong plug and ensure there's continuity between the ground pin and the metal frame of the grinder.
Other then that, it looks real nice and complete.
Davefr
OR
i was thinking i have to clean the motor and lube the bearing
I wouldn't as long as it runs smooth, quiet and coasts for a long time after being turned off.
If you remove those end caps to access the bearings it's easy to screw up that critical air gap alignment between rotor and stator. In other words, if it ain't broke, don't fix it.
drivesitfar
Faisal: be careful taking it apart and please do read some of the block grinder thread. more than likely it just needs a new plug like DaveF mentioned and it's good for 20 years. you can change bearings if you are talented and they are needed, but since they are enclosed there won't be any simple greasing of them.
if you have a question on this block read some of the thread and if you still have any there are many helpful guys on that thread especially if you start participating yourself and getting back posts with results.
good luck
rsanter
visalia ca
Spin the wheels by hand. Does everything feel smooth?
Inspect the cord. Are there cracks showing bare wires? If so replace
Turn on. Does it make any funny noises? Does it smell funny?
When running does it vibrate? If so you may have to dress or replace the wheels.
Turn off and see how log the wheels take the stop. The longer the better
