Got a free fluke 83 multimeter
90zcar
I was at my brother in-laws house tonight and he does a lot of electrical work and I asked him if any of his co-workers ever upgrade their multi-meters to better ones and if they sell their old ones or what.
He told me to hold on a second as he went out to his shed and came back in and said "here ya go"...handed me an older fluke 83. I tried to give him something for it and he just told me to take it!
I popped a new battery in it and she came on.
It only had 2 black leads so I'd like to pick up a red one. Where can I get a new lead/leads for it that are good and how much do they run.
Up until this point I only had a little 5 dollar harbor freight meter I use for basic automotive testing.
Can anyone that has this model tell me anything about it? Is it a good one? Etc..
Sent from my iPhone 5s using Tapatalk
Bruce57
Central Ohio
It's a good meter for general electrical use and troubleshooting. Generally runs over $300 new. Your brother-in-law did you right.
Spinaker01
Toronto GTA
My main multimeter is a Fluke 83. Had it for almost 20 years and it is an excellent, accurate and reliable unit. Will measure anything an non-electronics guy would ever need to measure and then some. Great freebie! :thumbup:
Outlander
Quebec, Canada
This borders on meriting a 'you ****', but since it came from the BIL this might violate some unspoken rule. Enjoy your new meter!
platform389
If I were you, I would put a fresh high quality 9V battery in this, but a normal Duracell or Energizer would be fine as long as it is fresh from a large retailer.
Here is good advice. Even better, spend a little more, get a lithium 9v for it and reduce the chance for leak damage.
http://www.amazon.com/Energizer-LA522SBP-Lithium-Battery-Detectors/dp/B003VKOEBM/ref=sr_1_2?ie=UTF8&qid=1420119601&sr=8-2&keywords=lithium+9+volt+battery
Your test equipment will be instantly available for years to come.
90zcar
Thanks guys. Guess I did pretty well then. Yes I put a fresh Duracell 9v in it. Just wanna clean up the unit/casing a little bit yet. The actual screen still had the plastic protective film on it. Surprising for how old it is.
Should I stick with actual fluke leads like pointed above or could I go with these shown below for 7 bux. I don't think they are fluke ones
404
Mass
Most anything Fluke is great. The inexpensive leads will get you started. Later when the plating on the tips becomes less conductive and annoying or the wire inside breaks you can upgrade.
When checking that a circuit is off for safety, and want to be **** about it, first switch to ohms range with probes together to make sure there is continuity. Switch to volts and test, then do the ohms check again to make sure leads are still good.
Davefr
OR
Fluke leads are really nice but can be wayboverpriced.
There are some less expensive test leads at this site and they're really decent quality, have good reviews and only cost a few bucks.
http://www.dx.com/s/test+leads
redwrench60
East Tennessee
That's actually a pretty good meter. It's the non true RMS version of a Fluke 87 which is an incredible meter in function, accuracy and safety. Here's my 83-3. Good all around meter.
Since you got nothing in the meter I suggest you get basic Fluke leads since they account for a good portion of the safety of the meter. The basic leads aren't expensive, it's the interchangeable end leads that can be pricey.
You could just mark one of those black leads with red tape at each end and use it as your dedicated + lead.
redwrench60
East Tennessee
Factory Fluke TL75 basic leads are $13 plus shipping on Amazon. That's the way I'd go for that meter. You can always upgrade later or trade
tool_scrounge
Southern California
Search ebay for "military test lead". Nice sets with interchangeable tips for $9.40 +shipping.
Example:
http://www.ebay.com/itm/111192277507
The ones I have purchased are labeled as supplied by Elwyn Industries in Pa, and large numbers were supplied in the 1990s for the Gulf War. They are supplied in hermetically sealed pouches so they look brand new even thought the one I just opened has a 1990 date code on it.
But from what I read, Elwyn Industries does not make electronics. So it is suspected that they purchased the leads from someone else. The test leads look identical to the Keithley 1754 Universal Test Lead Kit, which costs $58.
http://www.keithley.com/products/accessories/testleadsprobes/?mn=1754
alt source of the probes (slightly higher cost):
http://www.davidriddle.com/elwyn.html
Cope
Houston, TX
You got the meter free, so invest in the real McCoy. I needed a new set for my 83, so I took the leads from my 87 and put them on the 83, and bought a set of the silicone Fluke leads for the 87.
90zcar
Everyone is right I should atleast get the actual good fluke leads...I'll have a whopping 15-20 bux invested total.
What's the difference between the tl-71 and tl75 leads?
Here's the TL71
Here's the TL75
Cope
Houston, TX
Here's the TL71
Here's the TL75
TL-71 appears to be a premium set. TL-75 looks like what came with my 83.
90zcar
I'll get the premium set then...gonna order em up tonight
xbeatles4x
Cutler Bay, FL
Nice score op. I also scored the same fluke 83 multimeter from a friend. He was leaving Miami to go to Buffalo. He just gave it to me. Replaced all the internal fuses as a preventive measure and new batteries and it is great. I might get new test leads but it is awesome.
If you don't know already go out and watch a few videos on how to use it properly. It can do things that I didn't know I could do.
Also thanks guys. I have been needing some new test leads. Now I have a few that are known to be decent. I once started to look up some but gave up.
Onefastgsx
Indiana
I have some of the offbrand leads from eBay you posted. They are very nice for the money. Im no pro, I just wanted some that would work well and laSt me a while. I'm going on 2 years with these and I use my meter quite a bit
90zcar
I purchased the fluke tl71 set. I figure I'll get good leads....I can always get add on pueces later
n8n
Curtis Bay, MD
your local electrical supply should have the leads, as well as the hanging accessories if they fit that model. Check and make sure that the fuse(s) are the correct ones and get those as well if not. Then enjoy!
90zcar
Yeah I gotta figure out what is gonna benefit me the most as far as cost n whatnot. Would like to atleast get a set of the alligator clips that slide on the end of the probes
Steinmetz
Washington State
Thats an awesome score you cant go wrong with a Fluke.
Prove - Test - Prove
Yes you can. I had to replace the display in mine several years ago. It had a flaw well-known to Fluke. It was made in Everett, WA, although I think that Fluke is made predominately in China now.
redmondjp
Redmond, WA
Those are very handy - I keep a pair of the clips in a tiny plastic bag in my primary toolbox.
Fluke AC175 is the part number you want - they are $11 on Amazon.
ttpete
Dearborn, MI
Same thing with my 8050A bench top. I also had to replace the battery packs because it won't operate on 120V with bad batteries. Found them on ebay.
Cope
Houston, TX
I cleaned the contacts on mine but the problem kept recurring. I bought a new display from an eBay seller and later found I could have gotten it cheaper straight from Fluke. My 87V and 52II are made in USA, but my i410 ammeter clamp is made in Thailand. This may be a byproduct of the sale to Danaher years ago.
90zcar
Thanks! Those are the ones I have been looking at. They should be able to open up wide enough to go around the clamp on car battery terminals right?
redmondjp
Redmond, WA
Not over the entire clamp, but over the bolt or nut on the clamp. The jaws open approximately 1/2" or so.
