Durasmack
Hi all! I'm in the process of building a new shop and wanted to solicit opinions from the experts on this forum. I've read hundreds of forums/ threads and 3/4" plywood seems to be the wall covering of choice.
Finished shop will be 54x56x16
The inside of my shop will be finished as follows.
4' white metal wainscot then 8' of either 3/4" plywood or 3/4" MDF, then 4' of white metal panel to the ceiling.
I went with 4' of metal at the bottom to combat any water that the walls may see from washing cars, etc....
I know that MDF is not at all water friendly, so I am sure that is why most people do not use it! However, since I am going with Metal on the bottom, why not use MDF on the top? MDF takes on paint much better than plywood.
Any thoughts, or would you still go with 3/4 Ply?
It's not a cost thing as MDF is roughly $33/ sheet and ACX Ply is roughly $38/ sheet. I figure I need 26 sheets so the difference is only $130 or so...
