I finished running the air lines the HF air reels. I found out the reels, even thought they were the same part number, same box, were not the same. One has a 3/8 inlet the other has a 1/4 inch inlet. Naturally I found this out after driving 30 minutes to Lowes to get the fittings. I lucked up and my old instructor from PCC was at HF right up the road from Lowes and was coming back over here to get paid for working on the float switch at the shop septic tank system, he stopped by Lowes for me and got the fittings I needed and brought them to me.
I got the sheet metal straightened out on the 5600 Ford tractor. If I can get the PS pump rebuilt in the morning, then replace the bent tie rod end and the other one, it might get painted in the afternoon along with the front end loader for it.
I dropped the Hydraulic cylinders off last week to get rebuilt. One has a bend rod and I had to cut the cross pin out of another to get it out. I'm guessing they'll be about $400-$600 to get fixed at the most. I didn't have time to do it myself, so I farmed it out to Rob Hydraulics. They've done me right before. Free seals to fix a free jack, I figured I'd let them deal with it.
When I start spraying Monday, I plan to spray the #1005 4ft Pexto 16 ga. bender I bought and stripped down to mostly bare metal. It's going to be JD Green, the correct paint code is $189 p/gal, $69 sounded better to me for JD green.
I cleaned the mouse **** out of Linda's car and set a trap for that POS mouse. It just moved it there in the last few days. the POS chewed a hole in the back seat where she had it folded down to haul the dog crates.
I've been so busy the past week, I've not has time to post all the fun I've been having.
Hunting parts for the radiant heat, air stuff, hydraulic lines for the tractor and fittings and checking out a few "broke" generators for folks in the middle of all this, it's been a busy week. at 10 PM tonight, it'll make about a 14-16 hours day in the shop again.
I'm ready for a BIG drink, something to eat and a bed or at least a couch to die on tonight.
