Tiny shop...with a view
archy99
Everett, WA
New member here, so a bit of an intro and a quick shop build story. I’ve really enjoyed reading some of the stories and build summaries that have been posted here. A ton of great info and quite the community you all have created!
I work as a project manager for an large architectural firm (commercial retail and some aviation projects), but had a previous life as an aircraft mechanic (FAA licensed but never really used the card...oh well). Did a stint in the air force reserve, and put in 15 yrs working at Boeing Commercial (worked on 737, 747, 757, 767, 777 lines, as well as on the last few 707 AWACS birds). I like to work with my hands....wood, metal, motorcycles, boats...whatever.
My in-laws have an old cabin on the Washington coast, which came with an old storage shed in the side yard that had seen (much) better days...it was completely unusable. In 2004, I had been laid off and had just finished my master's thesis so, after 8 years of full-time undergrad and grad school (while working full-time graveyard/swing shifts), I took the opportunity to get a little "down" time and rebuild the both the cabin's deck and get a good start on a new "shed". It would save my in laws a bunch of money, and they would get something that would hopefully last a while...and I would get some fresh air and a mini work-vacation in the deal...and a mini-shop. Win-win!
Built in '62, the cabin sits at the end of a winding, half-overgrown two track gravel road, tucked up on a knob of land surrounded by very old spruce trees, not too far from the southern edge of the Hoh rainforest. We’re the last house on the road, in a place where it rains roughly a million inches a year, and gets blasted by every bit of nasty weather the Pacific can muster. Truly a beautiful piece of property, with a commanding view of the ocean, but definitely not the easiest place to get a trailer full of construction materials into, as every stick of lumber has to get hand-carried around to the far side of the cabin. Really makes a guy evaluate how much concrete is truly needed when he has to hump every bag by hand. The nearest hardware store is fifteen miles away, so you better have brought everything you needed.
Over the first couple of weeks I tore out and rebuilt the cedar deck/benches/railings and then got out the chainsaw and went to town on the old shed...quite the bonfire going for a few days. I had a pretty good idea of what I wanted out of the new structure…storage for all the things you need at a remote cabin but really don't want taking up space in the main building, as well as a warm and dry place to fix small things…but I hadn't quite figured out what it should look like.
Once the old shed was down and the side yard cleared, it took a while to plan out the new structure, trying to fit the four post footings in between old trees and their roots, buried gutter collector pipes, etc while still being able to capture the view, but eventually I commenced to digging. I won't go into too much detail on the guts of it, but it's essentially a heavy "table" structure built right on the edge of the ravine going down to the beach, with three of the legs planted squarely in the yard, and one dropped over the edge into solid soils. The structure was rotated so the end window would have a view down the ravine toward the beach, and the long window in front of the workbench would stare straight into the woods and across the ravine, with no buildings or trace of man in sight. Keeping the size of the whole thing under 8x12 was key, as it allowed me to build without permits.
I got the heavy base framing and decking completed, and came back a few weeks later with another load of lumber to start on wall and roof framing. Walls are 2x6, and I used built-up ridge posts to support a built-up ridge beam and 2x8 rafters, giving me a 12' vaulted ceiling over 2/3 of the floor for tall storage (ladder and surf fishing rods), as well as a small storage loft over the door and most of the workbench. I framed and sheathed the whole thing myself, and then tarped it all up to keep it dry until I was able to find blocks of time to do the next big chunks of work. In the end, it took a week here and there over several years to complete it, installing Galvalume roofing and trim, cedar shingles sourced from a local mill, plywood interior surfaces, and a furred floor with 1.5 rigid insulation. I built the storage shelves to double as simple bunks, should we ever have too many people there to all sleep in the cabin...good spot for adventurous kids. It has 110v power, enough to run small tools, and rudimentary lighting (shop clamp lights). I still need to fit it out with a few things (a small space heater, a bench vice and some tool storage/tools), but for all intents and purposes, it's done.
All in all, a very comfortable place to work on cabin-sized tasks/projects, or simply enjoy a cup of coffee tinkering at a workbench with one of the best views I can imagine. First project completed at the bench was the replacement of a torsion rocker spring in an old modern leather Swedish arm chair...good luck with spares on that, so hand fabbed to fit. Worked like a charm!
Cheers! Go 'Hawks!
Surreal001
Wow what a great spot to have. You are very blessed! I love the use of space with the shelves doubling as spare bunks.
memphisnate
Memphis, TN
Nice shed/shop!
Modern Swedish arm chair? Sounds like Mid Century Modern which I'm a huge fan of...
Any pics of the cabin?
A
archy99
Everett, WA
Nice shed/shop!
The chair is one of two Gote Mobler Nassjo chairs...purchased in the early 70's in Germany, I believe. Not technically modern, I guess, but close enough for description purposes. See pics below. You can see the end of the 1/2" square spring steel bar welded into the end cap. This piece had sheared along a weak spot in the grain. Picked up a new 4' piece from McMaster-Carr, and with some fitting/grinding I got it to match what was clearly a metric (smaller) female socket.
The cabin is currently getting a new roof, with standing seam material to match the shed roof, and should be complete in the next week or so. The existing shakes are a great material (at least 24", with an 8" exposure, and almost an inch thick at the bottom), and were locally harvested/split, but they hold every needle that falls on them (as well as twigs and branches), and it doesn't help that the roofer that installed them neglected to use stainless staples. Anything not stainless or HDG goes back to nature in a big hurry down here.
Was just remembering something that helps describe how "end of the road" this place is. When I was doing the roof sheathing and panels, I had built a wall-mounted catwalk along the two long sides of the shed, and site-built a wide staging ladder of 2x for the yard side and used my 24' extension ladder on the ravine side. That ladder, fully extended, only came about a foot above the catwalk on that side, and while I was definitely concerned about a fall, I opted not to use a harness, reasoning that I had much better chances surviving a 30' fall to the undergrowth than hanging upside down for a week before anyone would use the trail to the beach and find my dangling carcass. Cell signal at the time was non-existant, unless you stood on the railing of the deck and even then you might get one bar, but seldom long enough to actually complete a call.
It was also my common practice to have a shotgun, loaded with slugs, nearby where I was working, as cougars and black bear are quite common in this area, and I was concerned my lab might bring a friend home. She had the run of the woods down there...I'd launch a tennis ball into the forest and she'd come back with it (or another one!) an hour or two later. Looking like the old girl will be going back down for the last time in the very near future, and getting a permanent view spot on the hill. :( 18 years is a great run for any dog, and Lucy deserves a great resting place.
A
archy99
Everett, WA
Appreciate the compliments. They were a great replacement for the old chairs that came with the cabin, and fit right in, being from family. Just needed a bit of work. I do wish the place was closer to my own house, so I could use it more often...but at the same time, I'm also glad it's not. Really makes you plan for long weekends and forced relaxation. We all need more of both!
Bwana
Santa Fe, NM
I lived outside of Marysville for 6 months or so while we were building modules in Wright/Shugart (?) Harbor. Stunning area. We too had a large cliff out back of the house where our dogs ran down to the beach.
Nice shop! As you said, perfect for tinkering or just a cup of coffee. Do you have palns for any heat? I remember is can get pretty chilly there.
Any interior shots of the house? That fireplace looks like it can heat the neeighborhood
A
archy99
Everett, WA
I'll just do a little portable space heater while I'm in it, so when it dies, I'm not out any big amount of cash. It's well vented, and so far moisture inside has not been an issue.
Since it's not my own place, I'll have to decline on current interior shots, sorry. Not missing anything really...it's just not my stuff. Hope you'll understand.
I will say that the place was a design (Haida Hide Home) by a guy named Einar Svensson, who also designed Seattle's monorail, and has continued with that business, recently completing a new monorail system in South Korea. There is a youtube of one of the cabins going together
and there are some interior shots. I plan to ride that monorail on one of my next business trips sometime soon. Pretty diverse portfolio for sure.
...and yeah, that fireplace is a monster. It used to have a pipe heat-exchanger with a blower that just about cooked you out of the house. Was very glad to pull that thing out of there when it died.
