Will 3/8 plywood sag on a ceiling?
summit151
Hello i am about to install plywood on the walls and the ceiling in my new shop. I have purchased 3/8 plywood already and the trusses are 24 inches on center. I am wondering if the plywood will sag? I will also be blowing insulation in
Thanks
SD396
Kelowna, B.C.
I'm pretty sure my ceiling is 3/8" ply on 24" centers and there is no sagging. House was built in '74. Walls I would go 5/8" or 3/4" for durability plus you can hang things anywhere you want without having to hit a stud.
boobag
only way it may sag, is if you have a lot of moisture or it gets wet a lot. but even then, it wouldnt sag much.
Morrisman
Angeles City, Philippines
I was planning the same thing but with 1/4" play, and bigger spacing. The thinner it is, the lighter it is, and it will only be to keep dust/air at bay, and provide a little insulation.
I also planned to screw 2" x 3/8" battens across to cover the joins, and also provide some support. Maybe paint them a contrasting colour, to fancy it up a bit. :thumbup:
buzz4041
South Texas
I'm on 16" centers for the ceiling and used 1'4" with no sag and insulated on top. On the walls I went with 1/2" for being able to hang something anywhere I want and it works well.
Cyberbear
California
It looks like most journal members are happy with 3/8" over head ply at 24" center spacing, but I'm a little leery about that, especially with the insulation weight and if you ever get a roof leak and the insulation becomes water logged, the ply may well sag. I suppose it depends on the quality of the plywood you are using.
ADSR
There can't be much diff in price between 3/8 and 1/2. Take it back and go for the 1/2.
ADSR
Very interesting. I'm wondering, totally from a cost standpoint, if OSB would be an option.
Been roof sheeting new construction at 24" OC with OSB for years. You have to use an aluminum H-clip between trusses. Works well. 7/16 OSB will be fine inside used like drywall.
diypolebarns
Arcanum, Ohio
Be certain you utilize plywood and not OSB. Plywood is inherently stronger than OSB. 3/8" will work, but if you are planning on blowing cellulose insulation in your ceiling you will want to move to 7/16" OSB or either 1/2" plywood or OSB. It is also best to use a plastic vapor barrier above your ceiling and be certain the attic space is well ventilated. This will keep the moisture issue in check.
charlie v
Surrey, BC
+1 on that
