bimmer1980
I am currently designing my own garage to be built in York, PA. I have a question on the footing for the garage. I would like to use a monolithic style slab that has the deepened perimeter for the footings. The deepened part would be about 12” wide (minimum) and 12” deep (minimum) and slope up to the slab thickness at a 45 degree angle. The slab will be about 4 to 5” thick. I’m planning to install radiant heat in the garage and I was planning to install at least 1” polystyrene and vapor barrier. Ideally, I will install 2” of insulation under the slab. This should protect against frost, etc. Rebar would also be used in the slab and the integrate footings. I would also be planning to keep it covered during the cure for at least 2 weeks (my ideal is at least 28 days). I would also be cutting joints at around 8 to 10 feet.
The site is nearly level and would require minimal grading. I’m planning to put down at least 4 to 6” of crushed rock or gravel. That will be compacted prior to placing concrete.
Is monolithic slab on grade permissible for my garage application?
Thnoughts on this?
I emailed the PA building inspector group as well, but I wanted your guy's thoughts.....
Thnoughts on this?
