non chamfered sockets
4130rb
I work on lots of bike/motorcycle/snowmobile suspension where I run into shallow aluminum fasteners. I have quite a few inexpensive sockets where I've ground the chamfer off completely to get better engagement. I'd like to get a complete metric 6pt set of sockets with very low or no chamfer. Does such a thing exist? Is there a brand with lower chamfer?
heytrid
subbed to this for the exact same reason. good thing for cheap sockets haha
bwringer
Indianapolis
This is a mother-scratchin' freaking GREAT idea. The universal chamfer makes me crazy.
I've ground down several sockets in my day, but I'd love to be able to buy a nice metric set.
bonneyman
Desert SW
I take cheapie spare sockets and grind the working end flat.
The thin brass nuts on cooler floats are notorious for getting seriously corroding, seizing, and rounding off with normal sockets. Chamfer-free sockets get them off in a jiffy.
BFBOB
Ditto BMW swingarm pin locknuts. I've made suitable sockets on my little cheapie lathe. Cut the sockets to the shallowest possible to minimize tipping, and turn the face flat. Most have to have the walls thinned down a bit too. Grinding would be very tedious and imprecise, and hey, you needed an excuse to buy a lathe anyway, ri i i i ight?
T45
What sizes are ya'll takin about?
Just out of curiousity
JDon99
Desoto, MO
The Snap On low profile 3/8" sockets have little to no chamfer on them, only bad thing is they don't seem to have a large range of sizes and the metric is available in 6pt and SAE in 12pt.
bonneyman
Desert SW
Here's my little no-chamfer socket set. With a modified ratchet.
The problem is that the chamfer was designed to help slide the socket over the fastener if it wasn't perfectly lined up. But on thin or soft nuts, the chamfer (which is actually missing metal) means that there's very little "meat" of the broaching contacting the fastener. If it's thin and soft, it just rounds out. Getting rid of the chamfer allows a significant increase in socket to fastener contact.
I originally made 3 SAE sizes (9/16", 5/8", and 11/16"), and they worked so well I made another set for a buddy. (He likes them as well).
Then I started running into metric thin nuts, and made a couple of the sockets in metric (with the blue band). 15 and 16mm.
Don't use them everyday, but when I need em, they work.
bwringer
Indianapolis
Same as whatever we work on.
Personally, I mostly work on Japanese motorycles and cars, so 8, 10, 12, 14, 17, 19, 21, 22, and 24mm would cover most things (American/Euro machinery would need to add 13, 15, 16, and 18). I've also needed 27, 30, 32, 34(?) and 36mm at various times -- fork caps, triple trees, etc.
stovebolt6
Canada
Don't know about sockets, but my set of metric wrenches from Napa don't have a chamfer on the box end and they have actually saved my *** a couple times.
rhandwor
A few female torx and torx plus sockets are made with low countersink. Koken and Snap On and CTA has one.
