3 ph motor
Joebob37
Manchester Mi
I have a vintage 1/2 hp 3 ph Rockwell bench grinder w/ only 2 wires. I took it all apart, & theres only 2 wires coming from the stator. no sign of any burning, & no sign of any additional wires ever being there. the tag says "This motor has 3 wire leads" I can give some pics, & more details if needed. Hope someone has some answers.
Cheers
Joebob
LS6 Tommy
Northern NJ
Maybe it's a 2 phase motor... :p
Sorry. No help. I bet one lead broke off somewhere along the line. 1/2 horse is small for 3 ph. Sure it's not 1 ph? Pics would be good.
Tommy
canbug
Just North of Cow Town
There's a good chance that it is single phase with a ground? The third wire may have been attached to the frame somewhere. Just a thought.
Tim
big.jim
derbyshire uk
does it say it is 3 phase or just 3 leads, is there a rating plate ,does it look like it could have a capacitor
J
Joebob37
Manchester Mi
Hi guys;
Here's some pics. There are only 2 black wires coming out of the frame. The guy I bought it from thought it was single phase cuz of the 2 wires. If I remember right, he said when he plugged it in, it either hummed or turned slowly.
Cheers
Bob
dowmace
KCMO
Have you ohmed between the two leads? You should have a low ohm reading. Now ohm to the case and see what you get preferably nothing. I don't see where you should have had an extra leg.
Something is sketchy with it for sure. It's almost like someone pulled the casing and put new windings inside or something.
nehog
Jaffrey, NH
I'd inspect where the two existing wires enter the winding area and see if there is one more (broken off) wire there. I think it is a three phase motor (no capacitor to start, no switch) with a missing/broken wire.
Edit: check the area about 6 o'clock in your first picture. There are two pieces of tubing the 'top' one appears to have no wire to the right side.
Also inspect the windings to make sure that none have overheated.
alfredeneuman
Fullerton, CA
If you zoom in on the left lower picture it appears that 2 or 3 of the windings are burnt to a crisp.
It still doesn't explain the missing third lead though :dunno:
larry_g
oregon
The signage 'to reverse rotation change any connection of two leads' tells me this is a 3 phase motor. Your missing a connection wire.
lg
no neat sig line
DC73
Lubbock TX
Take it into a local electric motor shop and get their opinion. It wouldn't surprise me to find that somewhere along the line, someone had it converted from 3ph to use at a house or business that didn't have 3 phase service.
DC
big.jim
derbyshire uk
says three phase on the plate looks to me to have a burnt winding and probably a burnt off lead so either needs rewinding or dumping and replacing
DonPowers
On The Hair At The End Of The Dog's Tail
DC
Agree, that was my first thought that it may have been rewound in the past. If not, the shop could rewind it if it has a bad/burnt coil. In any event, bringing it to a shop is your best bet.
J
Joebob37
Manchester Mi
Yes, I think there is definitly a wire missing, but no evidence of it. I ohm'd the 2 wires together, bout 12 ohms, & infinity to gnd. The windings are not burned, it's the camera.I may start undoing ties, got nothing to loose. Thanks all you guys for your info.
Cheers
Joebob
tooler
Did you try running it on single phase? How was the switch wired? A 3 phase 3600 rpm motor should have 6 identical coils (windings). I would let an expert look at it before digging in to it.
Rob
404
Mass
Is there something broken off in the sleeve marked?
404
Mass
Bummer. Only thought is to take it like that to a motor rebuild place and ask. If the first guy you talk to doesn't know ask if someone else can come out to look at it.
abk241
SF Bay Area, California
I'm also seeing that.
Are those 2 empty holes for wire pass through at the bottom of the case?
Is that a burned up white wire sitting there? Or just a piece of twine?
